Release Asuswrt-Merlin 386.2 is now available
In addition to all of the other recommendations above, if you didn't perform a reset, then yes, you should perform a backup (really nice AMTM script to do this from SSH & command line), perform factory reset, then restore. If at all possible, restore everything by hand instead. If things go south you may have to do this anyway. This assumes that you've waited a day or so and have been able to get to the GUI indicating things have settled down and that you've been able to enable SSH. Good Luck!
I would strongly advise against restoring a backup, I would definitely start from scratch and you'll have a stable a router in no time at all. For now, just wait for the Asus maintenance (the reason you can't login) to be done, so that won't take as long when you start over. When you start over (yes 'when', not 'if') follow the guide by forum member @L&LD, it help you to get a good, fresh start:
Best Practice Update/Setup Router/AiMesh Node(s) 2021
I have installed 386.2 on GT-AX11000 and I report that it is impossible to activate the "optimized for xbox" function
That function is only for Xbox 360
Hello everyone just the problems on the RT-AC68U speeds have dropped and I barely got into the router settings so the router worked so slowly
When I start microsoft teams and after half an hour the router freezes and it is very difficult to enter the router settings
Firmware RT-AC68U_386.2
I noticed when i do two streaming and the router freezes and the internet speed drops
I solved the problem, I returned the previous firmware 386.1_2 and look at the miracles, lower CPU loads and lower RAM consumption and works more stably
Hi folks.
I'm trying to update from Merlin 386.1_2 to 386.2 on my AX86U
However, it says the image file is invalid. What should I do?
I'm trying to upload the "RT-AX68U_386.2_0_cferom_pureubi.w" file extracted from the zip using the manual firmware update option in the router.
I'm probably missing something as this is only the second time I use a Merlin FW.
Thank you.
AX86 vs AX68...
it doesn't work anyway, I didn't say it doesn't work with a particular console
Don't know if it helps, but I always putted my console in DMZ. And never had issues. The only issue I've now is my Nvidia Shield, where I see sometimes bad streaming, but first I've to rule out it is coming from my AX86u
For Android it can also change again when you restart your device, so I wouldn't count on it leaving that feature on for your own private network.
For iOS it works pretty good, it seems.
I use it at home; the IP address has survived modem/router/iPhone/iPad reboots and router/iPhone/iPad firmware updates.
I've updated my aimesh RT-ac68u and then changed the 5 G wireless channel to 104. Now the 5 Ghz works again on the aimesh node.
But if I look at the aimesh node it states there are devices connected wired that are connected to my ac5300. So it does not keep track on what is actually connected to a node or to main router. Not a big issue, but at least it now works :)
edit: typo
Dear Merlin,
Can you consider option to set 0 in Upload/Download Bandwidth manual setting in order to disable upload (edgress) shaping or download (ingress) shaping separately for QoS?
Upgraded my GT-AX11000 last night and so far so good. Everything stable. And thank god i can use VPN server and client at the same time again. This is not possible with the ROG firmware of this router.
Keep up the good work and thx.
Dear Merlin,
It's a bug in the Cake implementation that has been fixed here https://github.com/RMerl/asuswrt-merlin.ng/commit/b334f7df256a9763a90a9ee80e6b01979b44449b and should be in the next release.
In the meantime you can install CakeQOS-Merlin alpha and use the Custom Download/Upload Parameter "unlimited" instead
Just Upgrade from 384.19 to 386.2 on AC86U, all ok with the process and setting. Want to use Dnsfilter, which one is recommended or common to set?
Where is the build located?
@RMerlin The GT-AX11000’s 2.5 GB gaming port I believe uses the AQR109 which supports standard up to 10Gbe connections “in theory”. Would it be possible to make this port work at those faster speeds or would the cpu not be able to handle it? Just curious because it would give this router a massive feature boost.
No, it's a Broadcom chip, not an Aquantia.
I can't upgrade my RT-AC68 from 386.1_2, after upload firmware and 100% of upgrade progress process stop with this message:
Invalid Firmware Upload
To comply with regulatory amendments, we have modified our certification rule to ensure better firmware quality. This version is not compatible with all previously released ASUS firmware and uncertified third party firmware. Please check our official websites for the certified firmware. Is interesting - the message is displayed in Edge, Chrome but not in Firefox (it return to login page without message)
