ok i managed to reproduce the problem of the leds..No luck, What I did was restore the router via the web UI with Initialize ticked, After it rebooted I went and entered the web UI via, http:\\router.asus.com\Advanced_System_Content.asp entered my password etc, then did the disable LED's via the UI, It worked like before, as soon as I click to enable the Led's again they did not work. So I then did a Hard reset of the router holding the WPS, after rebooting i did the above again with the same thing the LEDs will not come back on, so I then did a UI Restore again and still no luck here's a video.
LED Video HERE
Also setting up the router I noticed that if I select secure login via HTTPS, it still shows for both see picture, yet should only show the one HTTPS unless both Is selected.
Also another problem with that page is the Auto Logout, It will not Auto logout.
So something I have noticed is that the 3 problems I have noticed is with the one above page in the UI.
@TrebleTA Yes still support all routers menthioned here https://github.com/gnuton/asuswrt-merlin.ng and I the DSL-AX82U is my main router at home.
As for new firmware I am working on that and it will be based on ASUS 48966.
Not sure, all other routers display their own picture correctly, also no problem via the app. Only via web gui, it wont display its own picture.Must be model related, my dsl rt- ax82u shows. Via app
Via web UI
P.s also says blocked by client, is that not your firewall or a blocker on you device nor the router?
This happen to me, maybe you use the adguard i was this problem and i solved with exception on adguard and done.Thanks for the hardwork to make this firmware available, just loaded it up onto my new rt-ax82U, and the only problem I have noticed (my OCD), is that the router is not displaying its own picture. I have tried a full reset and manual build, no luck. Also, dumped, (cleared), browser cache, to no avail. Tried in both Chrome and Edge. Phone app in both Anroid and IOS works without any issues. See attached screen dumps. ASUS stock firmware also does not have this issue.
Any ideas on how to fix this?
Welcome To SNBForums
