Issue: unable to configure LED lights off on an Aimesh node device. The node is in the bedroom, so having LED lights off is important.
Setup: RT-AX88u as the Aimesh provider and RT-AX56 as the Aimesh Node, with a wired backhaul. I configured the AX88 LEDs off (Administration > System > Basic Config > LED off "yes"). I did the same in the AX56 before setting it as a Node in Aimesh, however, the node did not retain the setting. The main unit does retain the setting. The firmware is Merlin 386.1 (latest release) on both routers
The AX56 IP is in the AX88 DHCP table at a fixed IP and I can ping the node IP when it is in the aimesh. However, I cannot reach the admin page. Some node settings (e.g. USB) can be reached via the AX88 admin page, but not the LED setting on the node.
Does anyone have a solution?
