[Asuswrt-Merlin] Export data "traffic monitor" from N66 to import AC66
It's possible??
I save data of "traffic monitor" in a USB Key
Yes, however you will need to rename the datafile.
Once you are on the AC66U configure Traffic Monitoring to point to a folder on the USB disk. Then, reboot and check syslog. You will see errors about rstats being unable to locate some file with a random-looking filename. Rename your N66U data file to that same filename (something.gz), and the router will start using it.
Sorry...i have a problem....i lost the pen usb disk :(
i have another question:D
About this function, i plug new pen usb ob RT-AC66U whit this set:
After 7 hours, i reboot the router, but not save my data traffic :(
There are other step for save data traffic on USB pen drive?
Yes, you must create a new database if it's a new USB disk. Select "Create or reset datafile" then apply.
ok,
today i select "Create or reset datafile" and after 7 hours, i reboot my router: no save data traffic :(
If i put the command:
/mnt/sda1/
on "run cmd", show me:
sh: /mnt/sda1/: Permission denied
It's right?
That is a path, you can't "run" it like that.
Connect to telnet, and try to cd into it.
Also, I recommend creating a directory there, and using /mnt/sda1/directory_name/ instead to store your database (don't forget to re-create the database).
I have the latest RMerlin firmware but I do not see that option (Other Settings)?
I want to periodically export the bandwidth logs as well.
It's under the "Tools" menu.
