For several days I have been trying to set up the VPN Client configuration, with the rules policy, in the Merlin firmware. I came to the conclusion that the firmware has no ability to operate 'policy rules'.
It is even possible to make an initial configuration, as below:
However, when applying the configuration, the system returns with the screen unconfigured, according to the following:
After a few attempts, it is even possible to apply the configuration so that the device list is organized, as shown in the first 'print'.
But, if you need to change any device so that it stops passing through the VPN and passes only through the WAN, when applying the configuration, then again, the list will be all unconfigured, as shown in the second 'print' and, worse, when the list is unconfigured none of the devices go through the VPN, even though this appears connected (on).
I only purchased AX88u for use with Merlin, specifically to access VPN policy rules. So far total disappointment .
