AutoBW: Automatically set QoS bandwidth using spdMerlin
@squidbilly @maghuro
Just gave a reboot to my device and unexpectedly AutoBW version 1.4 failed to start, manually tried to start and got this
thunder@RT-AC88U-5940:/tmp/home/root# /jffs/scripts/AutoBW
 TEST MODE: No changes will be made.
               ----------- SPDMERLIN --------
               Download (Kbps)  Upload (Kbps)
Test  1 of  2      39966.7         40745.0
Test  2 of  2      36925.4         28313.6
Average            38446.1         34529.3
Scale Factors          0.90            0.90
Scaled Speeds      34601.5         31076.4
               ------------- QOS ------------
Previous               0.0             0.0
New (from above)   34601.5         31076.4
Scaling by             1.000           1.000
              ============================ DOWNLOAD =============================
               ------------- RATE -----------    ------------- CEIL -----------
Class          Previous (Kbps)    New (Kbps)     Previous (Kbps)    New (Kbps)
(standard_in) 1: illegal character: M
(standard_in) 1: syntax error
11                 printf: invalid number '1895Mbit'
    0.0         printf: invalid number 'ceil'
    0.0           printf: invalid number '1895Mbit'
    0.0         printf: invalid number 'burst'
    0.0
printf: invalid number '1249348b'
 0                 printf: invalid number 'cburst'
    0.0         printf: invalid number '1249348b'
    0.0               0.0             0.0
10                 524288.0         524288.0           printf: invalid number '1895Mbit'
    0.0
printf: invalid number '654311b'
    0.0               0.0             0.0
13                 524288.0         524288.0           printf: invalid number '1895Mbit'
    0.0
    0.0               0.0             0.0
12                 printf: invalid number '1048Mbit'
    0.0
printf: invalid number '1249378b'
    0.0               0.0             0.0
15                 314568.0         314568.0           printf: invalid number '1895Mbit'
    0.0
printf: invalid number '391951b'
    0.0               0.0             0.0
14                 419424.0         419424.0           printf: invalid number '1895Mbit'
    0.0
printf: invalid number '523126b'
    0.0               0.0             0.0
17                 104856.0         104856.0           printf: invalid number '1895Mbit'
    0.0
printf: invalid number '129575b'
    0.0               0.0             0.0
16                 209712.0         209712.0           printf: invalid number '1895Mbit'
    0.0
printf: invalid number '260750b'
    0.0               0.0             0.0
              ============================= UPLOAD =============================
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
 TEST MODE: No changes were made
Hi, I'm afraid there's something I'm missing. How do I make it run "for real"
 TEST MODE: No changes were made.
#Test Mode (run and calculate but do not make any changes)
# meaning no "nvram commit" or "tc class change" commands
# will be executed
# 1 = test mode (no changes), 0 = make permenant changes
test_mode=1
Previous               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
    0.0
    0.0               0.0             0.0
What do these commands show:
tc class show dev br0 | head -n20
tc class show dev eth0 | head -n20
I'm trying to run the command for install thru putty and get the following error: "No such file or directory"
I'm sure it's me doing something wrong...any ideas?
Update: I think I had to run this code 1st: opkg install bc
It's odd, the script was showing under jffs/scripts folder once I ran the curl command.
How are trying to run it? By typing: /jffs/scripts/AutoBW
Have you tried this command: dos2unix /jffs/scripts/AutoBW
All is good now! Thanks for the assist!
Does this look correct? I have 300/10 mbps thru comcast:
You have 300Mbps down and aren't setting anything even close to that. What did the output of the script look like?
I didn't input any numbers in the GUI, once I ran the script those #'s were automatically input there.
I'm also using VPN, can this be throwing my numbers off? This is what I'm getting:
UPDATE: Figured out my speed problem!!!
Hi squidbilly, what did I made wrong as I am facing an "(standard_in) 1: syntax error" ?
cheffe@RT-OG:/jffs/scripts# sh AutoBW
Test  1 of  2      60037.1         32020.5
Test  2 of  2       5120.0         29163.5
Average            32578.6         30592.0
Scale Factors          0.85            0.85
Scaled Speeds      27691.8         26003.2
Previous           48128.0         26624.0
New (from above)   27691.8         26003.2
Scaling by             0.575           0.977
 0                     0.0             0.0               0.0             0.0
I installed using:
curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 /jffs/scripts/AutoBW && sh /jffs/scripts/AutoBW
as statet above.
Good, it gives me these mistakes and I do not know what to do since I am a novice.
Execute the following command to download:
curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 AutoBW
Running the command above I get "chmod: AutoBW: No such file or directory"
Try
This works but I then get "ERROR: 'bc' is required but does not appear to be available."
@immi803 installing bc when u have entware it is as simple as:
opkg install bc
SO then this....
Seems like the OP should update the install steps
Got it to run!! Got this:
xxxxxxxx@router:/tmp/home/root# curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW && chmod 755 /jffs/scripts/AutoBW && sh /jffs/scripts/AutoBW
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 14245  100 14245    0     0  45803      0 --:--:-- --:--:-- --:--:-- 52759
Test  1 of  2      257321.0         37949.4
Test  2 of  2      443525.1         37918.7
Average            350423.0         37934.1
Scaled Speeds      297859.6         32244.0
* Download speed (297859.6 Kbps) > upper limit (102400.0 Kbps)
Corrected Speeds   102400.0         32244.0
Previous           1052672.0         40960.0
New (from above)   102400.0         32244.0
Scaling by             0.097           0.787
11                 157900.0         15359.9           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '262331b'
    0.0         printf: invalid number '1249258b'
    0.0               0.0             0.0
10                 52633.0          5119.9           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '65580b'
    0.0               0.0             0.0
(standard_in) 1: illegal character: K
13                 315801.0         30719.9           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '64Kb'
    0.0               0.0             0.0
12                 105267.0         10240.0           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '131162b'
    0.0               0.0             0.0
15                 52633.0          5119.9           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '38389b'
    0.0               0.0             0.0
14                 105267.0         10240.0           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '50Kb'
    0.0               0.0             0.0
17                 52633.0          5119.9           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '12789b'
    0.0               0.0             0.0
16                 210534.0         20480.0           printf: invalid number '1052Mbit'
    0.0
printf: invalid number '25553b'
    0.0               0.0             0.0
11                  6144.0          4836.6           40960.0         32244.0
10                  2048.0          1612.2           40960.0         32244.0
13                  4096.0          3224.4           40960.0         32244.0
12                  4096.0          3224.4           40960.0         32244.0
15                  2048.0          1612.2           40960.0         32244.0
14                 12288.0          9673.2           40960.0         32244.0
17                  2048.0          1612.2           40960.0         32244.0
16                  8192.0          6448.8           40960.0         32244.0
I dont know what to make of this??
SO then this....
How did you get it started, since I received the same errors.
OOOOHHHHHHHH!!!
I am in a different directory...
SSHing in you are in /tmp/home/root and the script was put in /jffs/scripts/AutoBW
changing the install to:
Then run with:
I prefer:
curl "https://raw.githubusercontent.com/squidbillyms/AutoBW/master/AutoBW" -o /jffs/scripts/AutoBW.sh && chmod 755 /jffs/scripts/AutoBW.sh
Then run with:
sh /jffs/scripts/AutoB.sh
Just so it has an extension
