AX11000 / FlexQOS / Speedtest
skandi
I have an ASUS GT-AX11000 Router with FlexQOS installed (and the latest version of Merlin - 3004.388.8_4 ).
I have Nanit cameras and have found that FlexQOS was the best option to stop lag spikes caused by the Nanit Cameras.
Turning off Adaptive QoS in the Asus settings allows me to get full speed out of my connection.
Once turned on however i max out at around 500 MB/sec (using the routers built in speedtest).
Has anyone worked out how to solve this issue?
Use wired to the router device to do speed tests. Built-in speed test may not be accurate. And it's 500Mbps, not 500MB/sec (4Gbps).
Built-in speed test is not router to client. You have to test with a client wired to the router. Built-in speed test is also CPU dependent and accuracy may vary based on what else is running on the router.
