It would likely help others diagnose your issue if you provide more information. For example:Whenever i plug my pc into the 10gbps port and i try to play call of duty i get disconnected from the server
i’m new to all thisIt would likely help others diagnose your issue if you provide more information. For example:
What firmware is the router running?
Does the PC support 10GB or some lower speed?
Have you tried different Ethernet cables, particularly one rated for 10GB?
What does the router system log show around the time the PC drops the connection to the router or server?
Do you have any router features like QoS, AiProtection or other features enabled/configured, if so what is their configuration?
How is the broadband speed and latency?
How is the trace route and speed to the game server?
Does the connection drop happen at a specific time of day or is it random?
What ISP are you using and what speed?
Are you using any sort of VPN?
What are the WAN and or local DHCP DNS configuration(s)? Using Pi-Hole, Skynet or other DNS filtering type service or program?
yes that’s disabled
Welcome To SNBForums
