I am on latest Merlin. I had issues with the factory firmware the router had when purchased, any other firmware i tried was fine.Thanks. That's a bit more than the distance I'm using it from and same barriers, but it performs much worse for me.
Are you on Merlin or stock firmware, and could you tell me with what firmware you had issues and which one solved your issues?
PING 10.0.0.1 (10.0.0.1) 56(84) bytes of data.
64 bytes from 10.0.0.1: icmp_seq=1 ttl=64 time=1.33 ms
64 bytes from 10.0.0.1: icmp_seq=2 ttl=64 time=1.22 ms
64 bytes from 10.0.0.1: icmp_seq=3 ttl=64 time=3.96 ms
64 bytes from 10.0.0.1: icmp_seq=4 ttl=64 time=3.67 ms
64 bytes from 10.0.0.1: icmp_seq=5 ttl=64 time=3.97 ms
64 bytes from 10.0.0.1: icmp_seq=6 ttl=64 time=3.66 ms
64 bytes from 10.0.0.1: icmp_seq=7 ttl=64 time=3.65 ms
64 bytes from 10.0.0.1: icmp_seq=8 ttl=64 time=4.41 ms
64 bytes from 10.0.0.1: icmp_seq=9 ttl=64 time=5.43 ms
64 bytes from 10.0.0.1: icmp_seq=10 ttl=64 time=3.69 ms
64 bytes from 10.0.0.1: icmp_seq=11 ttl=64 time=4.56 ms
64 bytes from 10.0.0.1: icmp_seq=12 ttl=64 time=3.95 ms
64 bytes from 10.0.0.1: icmp_seq=13 ttl=64 time=3.51 ms
64 bytes from 10.0.0.1: icmp_seq=14 ttl=64 time=3.66 ms
64 bytes from 10.0.0.1: icmp_seq=15 ttl=64 time=4.14 ms
64 bytes from 10.0.0.1: icmp_seq=16 ttl=64 time=3.77 ms
64 bytes from 10.0.0.1: icmp_seq=17 ttl=64 time=3.70 ms
64 bytes from 10.0.0.1: icmp_seq=18 ttl=64 time=4.05 ms
64 bytes from 10.0.0.1: icmp_seq=19 ttl=64 time=2.55 ms
64 bytes from 10.0.0.1: icmp_seq=20 ttl=64 time=3.75 ms
^C
--- 10.0.0.1 ping statistics ---
20 packets transmitted, 20 received, 0% packet loss, time 19034ms
rtt min/avg/max/mdev = 1.222/3.630/5.429/0.942 ms
Regarding WMM No-Acknowledgement my opinion is very negative. Although i have 0 interference in my house it introduced problems when i enabled it so my suggestion is to keep it disabled.I tried both with enabled and disabled. Which do you suggest I use?
Thanks a lot!
This is a bunch of useful data. Should I treat all ping data as consistent?
Also, is dale connected via wire or WiFi to Zenmaster? I can see it has AX and 100mbit wired, so I guess it's wifi to it?
- the damn thing is adding a 1ms for each wired connection and 2ms for my HGW. I don't have sub 1ms pings from my wired devices, I get ~1ms wired. So if it's a switching issue, that 1 or 2 ms of added latency does in fact account for what I see on WIFI. That'd give me 1.5-3.5ms on wireless which is probably as much as you can get.
Yeah power saving mode is good for one thing, and it isn't performance. I haven't gone to W11 yet but there must be somewhere you can adjust the power level when on battery, but mine works fine on th medium setting when on battery. Haven't checked the difference in ping times.And hell yeah does battery power destroy my latency! I've done all my tests with the power bank attached since I don't have a setting for power saving on my AX211 in W11. It adds 5-10ms!
BUT it is noticable - I see spinners on websites I haven't seen yet. If it really adds that much,
Modern switches should add only a small fraction of a millisecond each so should not be a big concern on that part. Just about anything you buy will be better than the cheap switch built into these. I have a $25 TP-Link smart 8 port switch that outperforms the built in asus a bit.2 switches that I plan on using (one 1Gbps and one 2.5Gbps) will probably do a lot more damage to the network.
But there's another issue - the damn thing is adding a 1ms for each wired connection and 2ms for my HGW. I don't have sub 1ms pings from my wired devices, I get ~1ms wired. So if it's a switching issue, that 1 or 2 ms of added latency does in fact account for what I see on WIFI. That'd give me 1.5-3.5ms on wireless which is probably as much as you can get.
Bummer to do it for 2-3ms added latency BUT it is noticable - I see spinners on websites I haven't seen yet.
Have to confess that I've been using GNU-Linux at least 99.999% since about the time the 2.0 Linux kernel and discussion of a.out vs. ELF was relevant topic (likely Windows 95 was fixin' to debut). Also, that pretty much the last time I'd set up a network at home it was 100Mb and dialup, pretty much, until a bit over a year ago when I got the XT-8s to replace the failed fiber-provider-provided (1/2G symmetrical, CGNAT'd feed) Netgear AC 1700 (or so) "router."I've never had such a responsive network as that which I now have.
Welcome To SNBForums
