AX86S and 388.1 final-388.2 Alpha builds
  • Thread starter Deleted member 84281
  • Start date
Understood and thanks. I just thought you thought they were same model. Apologies.
Just to add an extra data point, it's not just the AX86S's experiencing this.
My new AX86U_Pro on 388.1 is also experiencing this problem. RAM starts from boot at a hefty 76% of the 1GB, and then slowly creeps up. Just rebooted now after seeing it at 97%.
Htop showed that networkmap and sysstate were indeed the culprits.
Have added jtp10181's script from the other OOM thread to kill networkmap and sysstate periodically, and hope that is a bandaid until this gets fixed upstream.
Oddly I had spike on AX86U’s RAM recently, around 97% on reboot. Probably because of “big” blocklist on Diversion (wished I check top/htop before). I disabled all scripts, disabled jffs partition (saved jffs just in case), format on boot and changed the USB. Only had initial problem re-installing Skynet (swap file problem *facepalm) and now RAM at 76% max. Using medium size blocklist (300k) with Diversion.
There is something wrong. I am now on 386.5_2 and have everything running. I use Skynet and Adware and both are working perfectly. When I were on 388.1 the router became very unstable and unusable. Also out of the blue restarts....
