Backup Manual DHCP List?
Going back to the original poster's question, I have a suggestion.
If you create a file called /jffs/configs/dnsmasq.conf.add with this line:
dhcp-hostsfile=/jffs/etc/dnsmasq/static_leases
Then you can put all your manual DHCP leases into this file /jffs/etc/dnsmasq/static_leases which will survive firmware resets and is easily maintained using nano or vi.
The format of the static_leases file is:
xx:xx:xx:xx:xx:xx,hostname,a.b.c.d,time_to_live
for example:
00:0C:29:41:AA:BB,barney,192.168.0.50,10080m
I'm curious - does this work with the RT-AC68U in terms of the format of the file?
The reason I ask is that, running nvram get dhcp_staticlist, all I get is the MAC address and the IP address. No hostname or TTL.
I would like to bind the hostname to the IP/MAC setting on the 68U.
Those are two different things. He's talking about the dnsmasq config. You are talking about the webui config.
I see. So, will the dnsmasq hosts file override the webui config? Should I use one over the other or just make sure both are in sync?
The firmware uses the addn-hosts config setting in dnsmasq.conf to provide the webui static reservations. No idea how it will interact with adding your own entries, you will have to see the dnsmasq documentation.
I am totally new to Linux so pardon my ignorance however the directory "/jffs/etc/dnsmasq/" does not exist on my router. Do I have to create it or can I use an existing directory??
This is what I have so far but it fails because "Directory does not exist.... "
1) echo "dhcp-hostsfile=/jffs/etc/dnsmasq/static_leases" >> /jffs/configs/dnsmasq.conf.add
2) echo "EC:1A:59:68:5D:19,Foyer Motion,192.168.1.201,10080m" >> /jffs/etc/dnsmasq/static_leases
Step 2 fails....
Of course, you have to create the directory before running 2nd line. For this example by running this:
mkdir /jffs/etc
mkdir /jffs/etc/dnsmasq
mkdir /jffs/etc
Custom config files must go into /jffs/configs/ if you want the firmware to automatically pick it up.
You are right and my message is completely in line with it. There was an example for /jffs/configs/dnsmasq.conf.add file with row
dhcp-hostsfile=/jffs/[B]etc/dnsmasq[/B]/static_leases
so it is the reason I gave him this help. It's just the directory for static_leases data file not dnsmasq.conf.add one. It should prevent him from the error message he's got.
I had figured as much but I was reluctant to make any changes to my router without confirmation. For all I know creating the directory and not setting proper privileges and my router will no longer boot without errors:D
Ok so I run the nvram get dhcp_staticlist command via Tools\Run CMD on my router.
The response is <MAC>IP.IP.IP.IP>HostName<MAC>IP>Hostname etc
I can save that single line off some place. If I just want to restore that single line and nothing else (and not backup the entire nvram to a settings file) would I just run:
nvram set dhcp_staticlist="long string from above with 20 or so MACs/IPs/Hosts"
nvram commit
nvram commit
correct
10char
for example:
I use this exact format for static_leases and get "bad DHCP host name at line 1 of /jffs/etc/dnsmasq/static_leases"
The Line I use is:"a4:ba:db:fb:84:ae,ALIENWAREPC,192.168.1.230,10080m"
Router: N66U, FW:3.0.0.4.374.39 (Merlin build)
nvram commit
I tried the above method as well however my line is too long. If I cut the list I got from "nvram get dhcp_staticlist" in half it works fine but I need a means to get the entire list back in.
Same problem here. It's not possible to paste the full output of "nvram get dhcp_staticlist" in the "Tools - Run System Command". And it doesn't seem possible to chop it up in several parts either, because only the last ran command(nvram set dhcp_staticlist) is applied...
Any tip on how to get the whole list back?
I use a script maintained on Windows Norepad++ and simply dragged/dropped into /jffs/scripts using WinSCP
#!/bin/sh
# Martineau Refresh a sorted list of the DHCP STATIC table
logger -t "($(basename $0))" DHCP static table reset
nvram set dhcp_staticlist="<xx:xx:xx:xx:xx:xx>nnn.nnn.nnn.nnn>Name1<xx:xx:xx:xx:xx:xx>nnn.nnn.nnn.nnn>Name2   < repeat etc. "
nvram commit
I have currently 29 devices defined.. and sorted by I/P! :-)
Regards,
You can break the data up into multiple lines using a (\) backslash.
Example
nvram set dhcp_staticlist="<xx:xx:xx:xx:xx:xx>192.168.1.200>Nest Thermostat<xx:xx:xx:xx:xx:xx>192.168.1.201>Foyer Motion<xx:xx:xx:xx:xx:xx>192.168.1.224>Kathys iPad \
<xx:xx:xx:xx:xx:xx>iPhone 2<xx:xx:xx:xx:xx:xx>192.168.1.249>Balboa Spa"
nvram commit
Example
nvram commit
How do I put this in Tools - Run System Command? It doesn't allow everything in one row. I am a noob, so please be more specific on how to input this in the Run Command view.
Hhhm. I used putty.exe not the "Tools/Run Cmd". Under Admin/system enable JFFS+Format JFFS+Telnet+SSH then download putty, install and connect SSH.
once you log on you can paste your list at the command prompt
i.e (assuming your list is broken into 2 lines
Line 1 = nvram set dhcp_staticlist="<xx:xx:xx:xx>192.168.1.200>Nest............ \ (Note backslash followed by <enter>)
Line 2> xx:xx:xx:xx>192.168.1.222>whatever..... " (Note Quote followed by <enter>)
How can we do this on the N66U now that the command line tab has been removed?
