Viktor Jaep
Part of the Furniture
Dang! Those are some sweet instructions!
Have you been able to get to this folder from another device on your network?I created and changed destination folder to Backup2 to be sure the folder's properties on the NAS were not causing the issue.
Perhaps "Erweiterte Freigabe-Einstellungen verwalten" ?In my German version of Win 10 I can't find anything similar to "manage advanced sharing settings". But I will probably figure that one out tomorrow.
That did the trick. I finally found it.Perhaps "Erweiterte Freigabe-Einstellungen verwalten" ?
In English, according to the Googles, in Windows 10 you go to Start > Settings > Network & Internet > Advanced network settings > Network and Sharing Center > Change advanced sharing settings.
Yes no problem. Can see files, move files, copy files to folder specified for destination secondary backup on NAS.Have you been able to get to this folder from another device on your network?
Do you have to manually specify which version(s) of SMB that this share can utilize? I know you said it could handle 2.0 - was that the maximum? Have you tried setting it all the way down to SMB v1.0?Yes no problem. Can see files, move files, copy files to folder specified for destination secondary backup on NAS.
I do have the option on the NAS but when I set it 1.0-2.0 the NAS warned about security issues and recommended not to do it. I will set it at 1.0 and give it a try and see if it makes any difference.Do you have to manually specify which version(s) of SMB that this share can utilize? I know you said it could handle 2.0 - was that the maximum? Have you tried setting it all the way down to SMB v1.0?
Yeah, it would just be to test... Any firmware updates available that would perhaps be able to raise the SMB version?I do have the option on the NAS but when I set it 1.0-2.0 the NAS warned about security issues and recommended not to do it. I will set it at 1.0 and give it a try and see if it makes any difference.
@Viktor Jaep
Let me know if the instructions require any updates:
See if these instructions help... this is on a local Windows 11 laptop.
1.) In the search bar, type "sharing", and run the "manage advanced sharing settings"
2.) Expand private networks, ensure that network discovery and file & printer sharing are both "on".
3.) Using file explorer, create a top-level folder somewhere on your drive... call it "backups"
4.) Right-click on "backups", and click on properties -> sharing
5.) Click on the "share" button, hit the drop-down, and select "everyone" -> add -> permission level "read/write" -> and hit the "share" button.
6.) Go back to your properties page, click on "advanced sharing" and just double check under "permissions" that you see "everyone", and they have "read/write/full control" permissions.
7.) At this point, you have a basic share that gives anyone access to this folder on your local network. You can get more granular by creating a local user/pwd, and assigning this user account to this folder... but let's just keep it easy for now.
You can now test access to your folder... copy this script into a test.sh file in your /jffs/scripts... make sure you change the IP to your laptop's IP address... and make sure the share is called "backups" or whatever you called it.
It didn't make any difference. Still can't mount the drive. Many tries both Network and NTSF and it can't mount the drive.Yeah, it would just be to test... Any firmware updates available that would perhaps be able to raise the SMB version?
Thanks but still no joy.
Running first command returns: Module md4 not found modules.dep
Second command after making necessary changes returns
mounting \\192.168.216.25\ on tmp/mnt/backup2 failed
mount -t cifs \\\\192.168.11.13\\Backup /tmp/mnt/backup2 -o "vers=2.0,username=myname,password=mypass"
There's a bunch of folks with Synology NAS's on this forum... Perhaps see if you can get someone to respond with the make/model/version you're running and see if you can compare notes?I will reach out to Synology and see if they have any suggestions.
I will let you know if I find out anything.
I have tried various paths thinking that might be the problem but I can't seemHey @CaptainSTX ... just looking at this again pulling my hair out... to find the magic.make sure your mount statement includes a \\\\server\\path... it seems that was cut off based on that output above? Also had noticed you had several nested subfolders in your target path. Perhaps try making it simpler like \\\\NASIP\\Backup ? Last thing... pay attention to upper/lower case of everything... sometimes it matters.
Code:mount -t cifs \\\\192.168.11.13\\Backup /tmp/mnt/backup2 -o "vers=2.0,username=myname,password=mypass"
Welcome To SNBForums
