Have been using an RT-AC86U for a few years now - with 2 AX92U nodes, plus an AX57. The first AX92U is wired, the others then connect via the AX92U. Diagram of current setup below. This is done via setting the AP preference for the nodes as represented in the diagram below. I get at worst a 300Mbps connection via the furthest node (the WAN is 1Gbps). It has been stable for ages, and very rarely disconnects, or causes any issues.
I decided to upgrade the AC86U to a BE86U (for the faster LAN/WAN speeds). The BE86U works great for the PC in the office - that gets a 1100Mbps speed instead of around 850Mbps before. However -the AIMesh is unworkable. With the same settings I find everything just tries to constantly connect to the BE86U, even the one that is wired. It never seems to use the AP preference that is set. The connections it makes to the BE65U are very weak, at best it gets 100Mbit and most times a speedtest is attempted the connection drops before it even completes.
So, before I send the BE86U back and just keep the old AC86U until it dies a death - does anyone have any ideas? I've tried both standard Asus and Merlin firmware - both with similar results.
Thanks in advance....
