After a good value wireless AC AP (or router) to upgrade my existing N network.
Doesn't have to have any features other than being a reliable, fast / good range AP as it will only be used as a dumb wireless AP (all routing functions done elsewhere)
Of course want to spend as least as possible but at the same time will spend extra if it's worth it.
For example, the netgear EX6200 can be had for $130, but then the TP-Link C7 is $150....not sure what the better wireless product is, but the netgear is AC1200 and TPLink is AC1750; so it would seem obvious that the extra $20 is worth spending.
Devices which are connecting wirelessly are:
Laptop with Intel 7260 AC (800Mb)
Two nexus 5's (AC)
Three other smartphones (N)
Two tablets (N)
House is double brick
Any suggestions welcomed
Two nexus 5's (AC)
Two tablets (N)
