applesnowleo
Regarding Link Agreegation, I have a problem that is present not only in this firmware but in all of Asus firmwares for AC5300, could be also for AC88 because they are the same, when using multiple LAG configs, with a Switch that supports this, and activate LAG on the AC5300 also connected to the switch, the router does not grab external IP in Vlan, also the fans on my two synology's go up to a higher rotacional speed.
The solution to this, as the router stops the boot sequence and can´t Access the router page, is disconnecing one of the two cables from the router in port 1 and 2, the router grabs the IP, and then connect the cable again. Strangly enough the fans from both servers after this, return to normal.
This is a strange behavior I have noticed, and because of this I do not use the LAG feature to serve wireless clients.
And the access to the router page is impossible with this setup, could be a bug, or could be a switch compatibility problem, but shure is one problem I Am facing.
