[Beta] Asuswrt-Merlin 384.11 Beta is now available
On the other hand, lack of EDNS support means Cloudflare can potentially degrade your overall network performance by pointing you at non-optimal CDN servers.
It's one of the reasons why, personally, after I'm done implementing and testing DoT, I intend to disable it, and go back to my ISP DNS.
I have yet to experience this issue but once I do , I am sure I will be looking else where for dns resolver
Perhaps things have improved since I was testing a few months back, but neither CleanBrowsing or Quad9 DNS over TLS were reliable, only Cloudflare.
Also the server side timeouts of CleanBrowsing and Quad9 were 2 seconds as opposed to Cloudflare's 10 seconds, so you need the following in stubby.yml:
idle_timeout: 1900
If you neglect to do this and have nvram stubby_debug set, you will see incrementing Conn_shuts. Here are normal results:
[00:55:01.541371] STUBBY: 1.1.1.1                                  : Verify passed : TLS
[00:55:11.518171] STUBBY: 1.1.1.1                                  : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9900
[00:55:11.518224] STUBBY: 1.1.1.1                                  : Upstream   : TLS - Resps=  1236, Timeouts  =     0, Best_auth =Success
[00:55:11.518246] STUBBY: 1.1.1.1                                  : Upstream   : TLS - Conns=   444, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
[00:56:01.713815] STUBBY: 1.0.0.1                                  : Verify passed : TLS
[00:56:11.695165] STUBBY: 1.0.0.1                                  : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9900
[00:56:11.695213] STUBBY: 1.0.0.1                                  : Upstream   : TLS - Resps=  1236, Timeouts  =     0, Best_auth =Success
[00:56:11.695245] STUBBY: 1.0.0.1                                  : Upstream   : TLS - Conns=   444, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
[00:56:14.756647] STUBBY: 2606:4700:4700::1111                     : Verify passed : TLS
[00:56:24.728211] STUBBY: 2606:4700:4700::1111                     : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9900
[00:56:24.728260] STUBBY: 2606:4700:4700::1111                     : Upstream   : TLS - Resps=  1235, Timeouts  =     1, Best_auth =Success
[00:56:24.728281] STUBBY: 2606:4700:4700::1111                     : Upstream   : TLS - Conns=   441, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
[00:56:14.795690] STUBBY: 2606:4700:4700::1001                     : Verify passed : TLS
[00:56:24.757123] STUBBY: 2606:4700:4700::1001                     : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9900
[00:56:24.757168] STUBBY: 2606:4700:4700::1001                     : Upstream   : TLS - Resps=  1236, Timeouts  =     0, Best_auth =Success
[00:56:24.757187] STUBBY: 2606:4700:4700::1001                     : Upstream   : TLS - Conns=   442, Conn_fails=     0, Conn_shuts=      2, Backoffs     =     0
Same here. I had dropouts with CB, Q9 wouldn't pass any DoT test, only CF works well accross the board here.
idle_timeout: 1900
what do you have in your config file for optimal setup with cloudflare?
Can anyone with IPv6 support confirm that the IPv6 Quad9 servers also work properly with DoT?
2620:fe::fe
2620:fe::9
A DoT test has to be specifically tailored for a specific server. The CF test will only work properly with the CF DoT servers.
Lack of EDNS support by CF was intentional, for privacy reasons.
Check how's your Akamai routing for example. Maybe just being pointed at a local CF cache might already provide localized enough information to no tend up using an Akamai server at the other end of the country.
idle_timeout: 1900
Boy, this does conjure memories of the growing pains with Stubby on John's fork. The conn_shuts are certainly undesirable and it's supposed to be better to let Stubby timeout the connection instead of the remote server. There's an open issue for stubby on github concerning this.
I can see this becoming a support issue going forward, depending on how many preset servers have timeouts less than 9000 ms.
I have checked them they do work. I can add them real quick and show you the stubby -l if you like
No need to, thanks. Will add them to the presets.
This is what the updated preset list looks like now:
# Layout:
# Name,IP_Address,Port,TLS_Hostname,SPKI
# Single entry = group label
# Empty lines are ignored
IPv4
CleanBrowsing 1 (security),185.228.168.9,,security-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (security),185.228.169.9,,security-filter-dns.cleanbrowsing.org,
CleanBrowsing 1 (family),185.228.168.168,,family-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (family),185.228.168.168,,family-filter-dns.cleanbrowsing.org,
CleanBrowsing 1 (adult filter),185.228.168.10,,adult-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (adult filter),185.228.169.10,,adult-filter-dns.cleanbrowsing.org,
Cloudflare 1.1.1.1,1.1.1.1,,cloudflare-dns.com,
Cloudflare 1.0.0.1,1.0.0.1,,cloudflare-dns.com,
Google 8.8.8.8,8.8.8.8,,dns.google,
Google 8.8.4.4,8.8.4.4,,dns.google,
Quad9 (secure),9.9.9.9,,dns.quad9.net,
Quad9 (insecure),9.9.9.10,,dns.quad9.net,
IPv4 (port 443)
Neutopia,89.234.186.112,443,dns.neutopia.org,wTeXHM8aczvhRSi0cv2qOXkXInoDU+2C+M8MpRyT3OI=
Surfnet/Sinodun 1,145.100.185.15,443,dnsovertls.sinodun.com,62lKu9HsDVbyiPenApnc4sfmSYTHOVfFgL3pyB+cBL4=
Surfnet/Sinodun 2,145.100.185.16,443,dnsovertls1.sinodun.com,cE2ecALeE5B+urJhDrJlVFmf38cJLAvqekONvjvpqUA=
IPv6
CleanBrowsing 1 (security),2a0d:2a00:1::2,,security-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (security),2a0d:2a00:2::2,,security-filter-dns.cleanbrowsing.org,
CleanBrowsing 1 (family),2a0d:2a00:1::,,family-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (family),2a0d:2a00:2::,,family-filter-dns.cleanbrowsing.org,
CleanBrowsing 1 (adult filter),2a0d:2a00:1::1,,adult-filter-dns.cleanbrowsing.org,
CleanBrowsing 2 (adult filter),2a0d:2a00:2::1,,adult-filter-dns.cleanbrowsing.org,
Cloudflare :1111,2606:4700:4700::1111,,cloudflare-dns.com,
Cloudflare :1001,2606:4700:4700::1001,,cloudflare-dns.com,
Google :8888,2001:4860:4860::8888,,dns.google,
Google :8844,2001:4860:4860::8844,,dns.google,
Quad9 (secure),2620:fe::fe,,dns.quad9.net,
Quad9 (insecure),2620:fe::10,,dns.quad9.net,
IPv6 (port 443)
Neutopia,2a00:5884:8209::2,443,dns.neutopia.org,wTeXHM8aczvhRSi0cv2qOXkXInoDU+2C+M8MpRyT3OI=
Surfnet/Sinodun 1,2001:610:1:40ba:145:100:185:15,443,dnsovertls.sinodun.com,62lKu9HsDVbyiPenApnc4sfmSYTHOVfFgL3pyB+cBL4=
Surfnet/Sinodun 2,2001:610:1:40ba:145:100:185:16,443,dnsovertls1.sinodun.com,cE2ecALeE5B+urJhDrJlVFmf38cJLAvqekONvjvpqUA=
As mentioned before, the only test servers kept on the list are for port 443, as none of the main production resolvers support port 443.
[01:50:25.762946] STUBBY: 2620:fe::9                               : Conn opene        d: TLS - Strict Profile
[01:50:25.854067] STUBBY: 2620:fe::9                               : Verify pas        sed : TLS
[01:50:25.956761] STUBBY: 2620:fe::fe                              : Conn opene        d: TLS - Strict Profile
[01:50:26.050073] STUBBY: 2620:fe::fe                              : Verify pas        sed : TLS
[01:50:26.114718] STUBBY: 2620:fe::fe:9                            : Conn opene        d: TLS - Strict Profile
[01:50:26.210824] STUBBY: 2620:fe::fe:9                            : Verify pas        sed : TLS
[01:50:28.116775] STUBBY: 2620:fe::fe                              : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9000
[01:50:28.117036] STUBBY: 2620:fe::fe                              : Upstream   : TLS - Resps=     1, Timeouts  =     0, Best_auth =Success
[01:50:28.117241] STUBBY: 2620:fe::fe                              : Upstream   : TLS - Conns=     2, Conn_fails=     0, Conn_shuts=      1, Backoffs     =     0
[01:50:28.147511] STUBBY: 2620:fe::9                               : Conn closed: TLS - Resps=     2, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9000
[01:50:28.147738] STUBBY: 2620:fe::9                               : Upstream   : TLS - Resps=     2, Timeouts  =     0, Best_auth =Success
[01:50:28.148299] STUBBY: 2620:fe::9                               : Upstream   : TLS - Conns=     1, Conn_fails=     0, Conn_shuts=      1, Backoffs     =     0
[01:50:28.272520] STUBBY: 2620:fe::fe:9                            : Conn closed: TLS - Resps=     1, Timeouts  =     0, Curr_auth =Success, Keepalive(ms)=  9000
[01:50:28.272741] STUBBY: 2620:fe::fe:9                            : Upstream   : TLS - Resps=     1, Timeouts  =     0, Best_auth =Success
[01:50:28.272924] STUBBY: 2620:fe::fe:9                            : Upstream   : TLS - Conns=     2, Conn_fails=     0, Conn_shuts=      1, Backoffs     =     0
My implementation has round robin enabled however, which apparently should be less problematic.
IMHO, CloudFlare is winning the (small) battle for DoT supremacy, so as long as your defaults work well with it, most people will be fine.
Me? I use Quad9 instead of CloudFlare. Firefox instead of Chrome. Butter instead of margarine. :p
DoT is still young. Once the kinks get ironed out and server admins have a better idea of the type of increase in server/network load it involves, we might see more providers supporting it. It will require a fairly significant critical mass for it to be supported by ISP unfortunately, as I suspect their existing DNS servers would require CPU and RAM upgrade to handle the extra load involved.
# cat /tmp/etc/stubby/stubby.yml
resolution_type: GETDNS_RESOLUTION_STUB
dns_transport_list:
  - GETDNS_TRANSPORT_TLS
tls_authentication: GETDNS_AUTHENTICATION_REQUIRED
tls_ca_file: "/etc/ssl/certs/ca-certificates.crt"
appdata_dir: "/var/lib/misc"
resolvconf: "/tmp/resolv.conf"
edns_client_subnet_private: 1
listen_addresses:
  - 127.0.1.1@53
upstream_recursive_servers:
  - address_data: 1.1.1.1
    tls_auth_name: "cloudflare-dns.com"
  - address_data: 1.0.0.1
  - address_data: 2606:4700:4700::1111
  - address_data: 2606:4700:4700::1001
idle_timeout: 9900
# cat /jffs/scripts/stubby.postconf
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_delete "tls_query_padding_blocksize" $CONFIG
pc_delete "round_robin_upstreams" $CONFIG
pc_delete "tls_connection_retries" $CONFIG
pc_delete "tls_backoff_time" $CONFIG
pc_delete "timeout" $CONFIG
pc_append "idle_timeout: 9900" $CONFIG
Has anyone noticed that /jffs/configs/profile.add is not working?
# cat /jffs/configs/profile.add
alias freshjr="sh /jffs/scripts/FreshJR_QOS -menu"
alias freshjrqos="sh /jffs/scripts/FreshJR_QOS -menu"
alias freshjr_qos="sh /jffs/scripts/FreshJR_QOS -menu"
alias FreshJR_QOS="sh /jffs/scripts/FreshJR_QOS -menu"
# freshjr_qos
-sh: freshjr_qos: not found
I created a workaround
# ls -la /opt/bin/freshjr
-rwxr-xr-x    1 HdB34266 root            32 Apr 27 16:42 /opt/bin/freshjr
# cat /opt/bin/freshjr
There is no need for an Apply button, the change is applied asynchronously to the router when you change it. Using an Apply button would require a rewrite of a large portion of that page, and isn't worth it.
Asus uses the same async method with the redesigned Virtual Server page now.
For me if No is selected, and I refresh / change page or tab, it goes back to Yes no mater what...?
# freshjr_qos
yea i stopped using fresh once i noticed devices periodically losing connection. not because fresh has a bad idea on his setup, but because ASUS is horrible with properly identifying traffic and I think they have made it worse and this doesn't help his script out. If i felt like re-identifying traffic myself i would to correct it, but at the end of the day it is too much work.
Didn't expect to read that.
