MDM
Ah, I see. So it will get fixed on its own in next build, tnx.It's because of a missing build time setting (merlinupdate wasn't enabled on these rebuilds).
That is why we have been asking for the second Quad9 secure resolver, 149.112.112.112. I see no reason for the Quad9 insecure. Google and Cloudflare are insecure.....And that's why it's listed as Quad 9 (insecure).
Is it an error, why does it list as secure (green)?Sorry...the listing was hard to follow...looked like 9.9.9.10 was the secondary address
Thanks for telling me! I look forward to upgrading after the beta testing is finished.the new beta has the force option too
RMerlin's option requires you to configure every client to use the router instead.
I suppose I just need to find out if ntpq etc. still works. Does the built-in ntpd support any configuration files?He's referring to this option that is added for beta 2:
Sorry for the blown-up screenshot, I guess Greenshot isn't high DPI aware...
Ok, i wasn't sure if it accepted the standard ntp.conf file that is called usually with -c (apologies if this was discussed before, I've been out of the loop for a few days)Not really, the only thing it supports through a config file is a list of servers. Config options are limited to what is supported by the command line arguments.
Most important is a dig test to see if you have the ad flagAwesome, thanks for sharing owine! That is the first real confirmation I've seen that it is an actual bug and cloudflare is aware of it.
For those seeking to verify dns security, note merlin's OP where he mentions using tcpdump. Also be aware, with the built in webui secure dns, if you disable dnssec you will only be giving up some additional security/privacy. I see no reason to give up dnssec just so a silly webpage test works, especially when there are more direct ways to test already.
DNSSEC validation is now done by dnsmasq, that's what this post was referring to. Therefore no proxying.
As written in the changelog: 45713 GPL, with 45149 binary blobs:
Code:- UPDATED: Other models to 384_45713 GPL (RT-AC87U, RT-AC3200 and RT-AC5300 still using 384_45149 binary blobs)
Keep an eye on @RMerlin 's change log.
I've enabled dns over tls and used cloudflares preset severs for ipv4 and ipv6 but on 1.1.1.1/help I get
Connectivity to Resolver IP Addresses
1.1.1.1 Yes
1.0.0.1 Yes
2606:4700:4700::1111 No
2606:4700:4700::1001 No
and looking in log I have no WAN IPv6 Gateway as its now empty. is there a way to fix this?
1.1.1.1 Yes
1.0.0.1 Yes
cat << EOF > /jffs/scripts/wan-start
#!/bin/sh
echo "1" > /proc/sys/net/ipv6/conf/all/accept_ra
echo "1" > /proc/sys/net/ipv6/conf/all/forwarding
echo "1" > /proc/sys/net/ipv6/conf/eth0/accept_ra
echo "0" > /proc/sys/net/ipv6/conf/eth0/forwarding
EOF
forgot to mention router is rt-ax88u and ipv6 was working fine on 384.10. even after rebooting still the same. thanksPuzzling. IPv6 normally works for you?
Reboot router perhaps?
make sure jffs custom scripts is enabled under administration on the gui
use ssh to make a wan-start script
Code:cat << EOF > /jffs/scripts/wan-start # #!/bin/sh echo "1" > /proc/sys/net/ipv6/conf/all/accept_ra echo "1" > /proc/sys/net/ipv6/conf/all/forwarding echo "1" > /proc/sys/net/ipv6/conf/eth0/accept_ra echo "0" > /proc/sys/net/ipv6/conf/eth0/forwarding EOF
make executable chmod a+rx /jffs/scripts/wan-start
if you already have a wan-start script (check using "ls /jffs/scripts" first)
you can
nano /jffs/scripts/wan-start
and copy and paste
to the end of the script
reboot afterwards
In the 384.10 and below versions, "Connect to DNS server automatically" = "Yes" means you will connect to your ISP DNS. Selecting "No" enables the option to specify a DNS provider of your choice in the DNS1 and DNS2 fields.The part that I struggle to understand is when you choose either “Disabled” or “Strict” option, what should the WAN settings be? More specifically, the “Connect to DNS server automatically”. Should the choice here be “Yes” or “No” (and your DNS servers of choice entered)? And why?
Welcome To SNBForums
