Good catch. I'm talking about the AC88U"88U" is not a valid model. Are you talking about an RT-AC88U (which doesn't support 160 MHz) or an RT-AX88U (which does support it)?
Click on the icon of the USB drive.The panel on the right will change from "System Status" to "External USB disk status". You'll then see an option (at the bottom of the panel) to "Safely Remove disk". Click on Remove and you're done.How do i Unmounted the USB drive via the GUI?
Just need to do the step @HorseCalledHorse mentioned in https://www.snbforums.com/threads/b...3_9-is-now-available.64792/page-6#post-595796.and how do i Removed the USB drive from the router, or what exactly does this mean ? do i have to put out something from the router ?
or is it the step that you said in the post ?
@RMerlin
The changelog is published for the end user, its absurd to then claim that the user doesn't need to understand it, and that's all I am trying to do.
Is it the case that the GPL release versions can't be compared across models? If so, can you include in the changelog from which model the gpl version is taken? Otherwise it's a meaningless number.
I did figure out the significance of "code is identical to 384_81846". 384_81846 GPL was used in a prior alpha, the chnagelog for which is not on the main changelog page. If you know this fact, the phrase makes perfect sense, it says the gpl code did not change between the alpha and beta, despite the version bump. But someone just looking at at the changelog page would not understand that. You knew perfectly well what I was asking and why.
Agree 100% or 110% as in sports. The changelogs provided by @RMerlin IMHO are very detailed and it doesn't take a rocket surgeon to figure it out. Badgering for MORE information is only understood when LESS is provided. @RMerlin already provides way MORE detail than other releases. I just hope we can convert @RMerlin to American football although the Canadian football is pretty good. Thinking Johnny Manziel.If you need that level of detail, do it yourself. Fork the project and examine line by line the code. Go explore the publicly available GPLs, learn.
If you're attempting to badger your way to get something not on offer, good luck with that.
Either way, take your demands to a different thread, just like all other non-beta related issues.
Pls can somebody help me on teamspeak i cannot install it
Is it possible to fix the Dutch interface the way it is fixed in p.e. RT-AX88U?
Welcome To SNBForums
