[Beta] Asuswrt-Merlin 384.18 Beta / 384.13_9 is now available
Noticed a small issue on my AC86U. Same issue in chrome and firefox.
Country code: Q2
And what is the issue exactly?
openvpn issues still .... it wont save the certificate authority keys when imported or manually put there ... worked in 384.17
No issue here. What router model? Did you check your System Log for any error message?
No issues with 384.18b1 running now on two AC86U main/AP combos. Port forwarding, site-to-site OVPN, TA, Parental Controls, USB thumb drive.
its rt-ac86u.... trust me theres an issue .... so if you have openvpn already installed from 384.17 and only upgrade it works just fine but i always factory reset after every build update to make sure everything functions and all and openvpn doesnt save the certificate when imported with opvpn file and if u manually add the keys it wont save, give it a try you will see , i dont know about other routers but rt-ac86u for sure has the bug can do video proof and i have checked the log wont even go cause its missing the keys ....
Using beta 1 for last 3 days 11 hours on AC86U and starting getting the following the log every few seconds:
Jun 23 20:07:14 kernel: Warning: ct_time_p->intv 0 ct->blog_key[BLOG_PARAM1_DIR_ORIG 0] 0xfffffffe ct->blog_key[BLOG_PARAM1_DIR_REPLY 1] 0x0
Jun 23 20:07:17 kernel: Warning: ct_time_p->intv 0 ct->blog_key[BLOG_PARAM1_DIR_ORIG 0] 0xfffffffe ct->blog_key[BLOG_PARAM1_DIR_REPLY 1] 0x0
Jun 23 20:07:20 kernel: Warning: ct_time_p->intv 0 ct->blog_key[BLOG_PARAM1_DIR_ORIG 0] 0xfffffffe ct->blog_key[BLOG_PARAM1_DIR_REPLY 1] 0x0
Jun 23 20:07:24 kernel: Warning: ct_time_p->intv 0 ct->blog_key[BLOG_PARAM1_DIR_ORIG 0] 0xfffffffe ct->blog_key[BLOG_PARAM1_DIR_REPLY 1] 0x0
Anything to worry about or needs checked? No VPN or other items configured. Basic router only settings.
Looks like that happened before on previous version based on this comment. I don't see where anyone references their comment so I would assume non issue.
https://www.snbforums.com/threads/r...-6-is-now-available.47941/page-14#post-421261
As I said, I cannot reproduce it here. I just imported a NordVPN ovpn config file, and both the static key and the CA certificate got properly saved.
Check the content of your /jffs partition and make sure it's not full.
admin@RT-AC86U-DFD8:/tmp/home/root# df -h /jffs
Filesystem                Size      Used Available Use% Mounted on
/dev/mtdblock8           48.0M      8.5M     39.5M  18% /jffs
Hi
The issue is the tab showing in the image. The GUI is set for English but the tab is Chinese. (UUAccelerator.asp)
I did not see this tab before this beta.
Was half a sleep when i posted. Should have been more clear.
Hi
The UUPlugin only appears for Chinese models, that's why it's only available in Chinese.
Either you are running a script that modifies your webui, or your router bootloader is configured for China.
Possible to add cloudflares malware dns or family dns ? They are the fastest ‍
Yes, it is possible: just go to the WAN settings and select the server or add the IP address... :rolleyes::oops:
Reporting from ax56u
Working fine, the 4th core is now working properly.
No device disconnection issues/can't connect when using smartconnect, used to reboot the router completely if my device cant connect (failed to obtain ip address)
But still classification tab under qos is broken :(
RT-AC88U
Please give this test build a try:
http://www.asuswrt-merlin.net/test-builds
Took a few iterations, but this one seems to work fine... so far.
I've been running this beta since you announced it. No problems here, all running smoothly.
Can you say any more about the GPL you're using? I see (at least from Asus's website) that they haven't released the latest GPL yet for the AC88U.
Thanks,
Anton
I'm seeing some crazy CPU usage on AC86U with latest beta 1. Only have diversion and cake-qos installed. Don't know if this is normal but apart from that everything seems to be working. Nothing out of ordinary on sys log.
Edit: ignore. It's diversion loggin when enabled causing CPU spikes.
Asus did a special build for me, and just sent me the closed source objects that I needed. It's not a full-blown GPL, the objects were based on 384_81918 code.
Everything has been rock solid here for 4 days. AC86U and a meshed AC66_B1. However, I'm still getting a ton of the kernel errors...
Jun 26 17:08:48 kernel: pgd = ffffffc008490000
Jun 26 17:08:48 kernel: [00000000] *pgd=0000000010fbc003, *pud=0000000010fbc003, *pmd=00000000097bb003, *pte=0000000000000000
Jun 26 17:08:48 kernel: CPU: 1 PID: 16196 Comm: dcd Tainted: P O 4.1.27 #2
Jun 26 17:08:48 kernel: Hardware name: Broadcom-v8A (DT)
Jun 26 17:08:48 kernel: task: ffffffc01e042040 ti: ffffffc0112ec000 task.ti: ffffffc0112ec000
Jun 26 17:08:48 kernel: PC is at 0xf6f01f44
Jun 26 17:08:48 kernel: LR is at 0x1dc74
Jun 26 17:08:48 kernel: pc : [<00000000f6f01f44>] lr : [<000000000001dc74>] pstate: 80000010
Jun 26 17:08:48 kernel: sp : 00000000ffab9828
Jun 26 17:08:48 kernel: x12: 000000000009ff08
Jun 26 17:08:48 kernel: x11: 00000000f61ff024 x10: 00000000000a075e
Jun 26 17:08:48 kernel: x9 : 000000000000001c x8 : 00000000000a0764
Jun 26 17:08:48 kernel: x7 : 000000000000001c x6 : 00000000f61ffe64
Jun 26 17:08:48 kernel: x5 : 0000000000000000 x4 : 00000000f61ffdfc
Jun 26 17:08:48 kernel: x3 : 00000000f61ffe80 x2 : 00000000ffffffff
Jun 26 17:08:48 kernel: x1 : 000000000007c66c x0 : 0000000000000000
