[BETA] RT-AC87U 3.0.0.4_378_8715
Back on this thread's topic, folks.
Doesn't seem like a lot of people complaining much about 5ghz and stability with this FW. Might try it.
No drops anymore but the battery drain is still there.... hope the find a solution to it.
Sent from my SM-G920I using Tapatalk
Wow! That sounds really exciting!!! How's hour experience? Do you think that we're really getting there finally? Could we finally have the drivers that Asus needs to produce an awesome suite???
Why do I brush after 8715 firmware, use 2WAN or 1WAN computers and cell phones are not the Internet, but the router's internal "network diagnostic but can ping through baidu", I do not know where to set the problem?
Hi binggesoft,
Wait for next beta build.
Traffic analyzer is gone, was in 8248. Wondering any chances to be available again in later firmware...
Is it really gone? I updated from 8248 to 8715 and I still have it! The only problem I'm facing now is slow USB 3.0 speeds. I have 2 TB WD hard drive plugged into USB 3.0 and I'm getting 10 MB/s read speed via Gigabit Ethernet connection.
Well, it was there even in AP mode to be certain. And I just revert back to 8248 then of course TA back again. After that, reloaded 8715 again and TA's gone unfortunately...All I did in AP mode. Or I may suppose my 87U to be ROUTER mode for making TA available, that's fine, I will.
Yes, I USB3.0 firmware also very slow. Past the old firmware speed about 50MB / S. Read up to 70MB + / but I do not know why now so slow speed USB3.0?
I drew a diagram CPU, 2.4G & 5G chip display, do not know whether the official added to it?
There's an option under "Professional" settings that reduces the USB3.0 to avoid causing interference with 2.4ghz radio.
Disable it if you don't care about 2.4ghz being affected when usb3.0 is working
it's normal behavior ?
Sep 17 22:59:57 ntp: start NTP update
Sep 17 23:00:39 disk_monitor: Got SIGALRM...
Sep 17 23:59:57 ntp: start NTP update
Sep 18 00:59:57 ntp: start NTP update
Sep 18 01:59:57 ntp: start NTP update
Sep 18 02:59:57 ntp: start NTP update
Sep 18 03:59:57 ntp: start NTP update
Sep 18 04:59:59 ntp: start NTP update
Sep 18 06:00:01 ntp: start NTP update
Sep 18 06:59:57 ntp: start NTP update
Sep 18 07:59:57 ntp: start NTP update
Sep 18 08:59:57 ntp: start NTP update
Sep 18 09:59:59 ntp: start NTP update
Sep 18 11:00:01 ntp: start NTP update
Sep 18 11:59:57 ntp: start NTP update
Sep 18 12:59:57 ntp: start NTP update
Sep 18 13:59:57 ntp: start NTP update
Sep 18 14:59:59 ntp: start NTP update
Sep 18 16:00:01 ntp: start NTP update
Sep 18 16:59:57 ntp: start NTP update
Sep 18 17:59:57 ntp: start NTP update
Sep 18 18:59:57 ntp: start NTP update
Sep 18 19:59:59 ntp: start NTP update
Sep 18 21:00:01 ntp: start NTP update
Sep 18 21:59:57 ntp: start NTP update
Sep 18 22:59:57 ntp: start NTP update
Sep 18 23:59:57 ntp: start NTP update
Sep 19 00:59:57 ntp: start NTP update
Sep 19 01:59:57 ntp: start NTP update
Sep 19 02:59:58 ntp: start NTP update
Sep 19 03:59:59 ntp: start NTP update
Sep 19 05:00:01 ntp: start NTP update
Sep 19 05:59:57 ntp: start NTP update
Sep 19 06:59:57 ntp: start NTP update
Sep 19 07:59:57 ntp: start NTP update
Sep 19 08:59:59 ntp: start NTP update
Sep 19 10:00:01 ntp: start NTP update
Sep 19 10:59:57 ntp: start NTP update
Sep 19 11:59:57 ntp: start NTP update
Sep 19 12:59:57 ntp: start NTP update
Sep 19 13:59:59 ntp: start NTP update
Sep 19 15:00:01 ntp: start NTP update
Sep 19 15:59:57 ntp: start NTP update
Sep 19 16:59:57 ntp: start NTP update
Sep 19 17:59:57 ntp: start NTP update
Sep 19 18:59:59 ntp: start NTP update
Sep 19 19:59:57 ntp: start NTP update
Sep 19 20:59:57 ntp: start NTP update
Sep 19 21:59:59 ntp: start NTP update
Sep 19 23:00:01 ntp: start NTP update
Sep 19 23:59:57 ntp: start NTP update
Sep 20 00:59:57 ntp: start NTP update
Sep 20 01:59:57 ntp: start NTP update
Sep 20 02:00:09 rc_service: rc 14085:notify_rc restart_wrs
Sep 20 02:59:57 ntp: start NTP update
Sep 20 03:59:57 ntp: start NTP update
Sep 20 04:59:57 ntp: start NTP update
Sep 20 05:59:59 ntp: start NTP update
Sep 20 07:00:01 ntp: start NTP update
Sep 20 07:59:57 ntp: start NTP update
Sep 20 08:59:57 ntp: start NTP update
Sep 20 09:59:57 ntp: start NTP update
Sep 20 10:59:57 ntp: start NTP update
Sep 20 11:59:57 ntp: start NTP update
Sep 20 12:59:59 ntp: start NTP update
Sep 20 13:59:57 ntp: start NTP update
Sep 20 14:59:57 ntp: start NTP update
Sep 20 15:59:57 ntp: start NTP update
Sep 20 16:59:57 ntp: start NTP update
Sep 20 17:59:57 ntp: start NTP update
Sep 20 18:59:59 ntp: start NTP update
Sep 20 20:00:01 ntp: start NTP update
Sep 20 20:59:57 ntp: start NTP update
Sep 20 21:59:59 ntp: start NTP update
for me its strange and i never before see that frequently time update....
If you setup the DST setting, it's normal.
