[Beta] RT-AC87U_3.0.0.4_378_8248 Unofficial Beta
poor_poor
Dear all,
Fix French UI
Fix bugs
New: Enable Traffic Analyzer
Update: IPTV ISP profile setting of 'movistar' & 'meo'
Update: Quantenna SDK: v37.3.0.50 (acR3.2.1)
Update signature into 1.066
Update: dnsmasq: 2.75
Update: openssl 1.0.2d
Update: adjust the maximum number of Guest Network MAC filter. (16 client per Guest network)
Fix: 5Ghz AP isolate issue
Fix: Allow $, ",` and \ in SSID and WPA-PSK for Quantenna
Fix traffic monitor issues
Update Extend max VPN clients to 30 for high-end models
Fix: [Adaptive QoS] [Bandwidth Limiter] less than the actual speed setpoint
Fix:[AiProtection] turn cause the machine to reboot repeatedly endanger website
Fix: [USB Application] USB HDD can not mount
Fix: [AiProtection] Parental controls time scheduling blocking message can not be displayed
Download: http://goo.gl/zdcNK6
Require: Restore to factory default.
Please feedback to me if you encounter any issue.
Already installed...testing session begins...
Sent from my SM-G900F using Tapatalk
long time no update...
most interested in new Quantenna SDK, ready to begin testing 5G stability.
thanks share it.
Dear all,
Fix French UI
Fix bugs
Link to source
http://forums.hardwarezone.com.sg/96093621-post4240.html
Sorry, just got this router and I have no idea how to reset to factory default. Is there a writeup somewhere on how to do this?
Strange that ASUS@SG didn't share the _8258 which is the one I received instead.
...so...why you do not share the newer version?...:)
Because I don't have release notes for it. I want to have it first or at least test it first to avoid things like _7944 which was terrible.
I'll test it and post it if I find it good [emoji6]
Replied through Tapatalk
Because I don't have release notes for it. I want to have it first or at least test it first to avoid thing like _7944 which was terrible
Ok, understood. (Y)
So far I've found a GUI issue when I select "AiCloud" Tab, it shows "USB Application" as selected instead, so I need to go to another tab in order to access "USB Application" one.
Well, and WPS issue is still present
WPS and Beamforming issues still there, great work ASUS. :)
Dear all,
Fix French UI
Fix bugs
Hey @poor_poor is the cell phone battery drain issue fixed in this build?
I won´t bet too much on this two bugs get ever fixed... seems like the Quantenna chipset wasn´t the right decission and Asus is now trying to limit the mess instead of rolling out the advertised features (mu-mimo, bean forming...)
I feel it is indeed beyond drivers and that we are actually facing some hardware inherent faults. A pity....
This is why manufacturers should not release half baked products. They should release products when it's fully functional, not "we'll fix it later" crap that they are doing.
If they don't deliver mu-mimo, nor fix the 5ghz issue, do we have grounds to sue? Or at least return the product and get a full refund past the 30 days of purchase?
I am thinking about taking this to small claims court if they don't deliver mu-mimo or at least fix the 5ghz issue. I am currently not using the 5ghz band because of this. I didn't buy a wireless N router.
After adding a "limited time" guest network the gui always shows "> 1 Minuten" as remaining time although there should be over 12 hours left...
