RT-AC87U_3.0.0.4_378_5587- Unofficial beta firmware
If you are on Firmware version 3.0.0.4.378.5134 do you still have to do a hard reset? it mentions if you you were on build 5556 that you didn't.
Any firmware version previous to 5556 must have a hard reset and reconfigure it all again manually (not using the cfg file).
If you already are on 5556 or newer and upgrade to 5587, then you don't need a hard reset
If anywone is logged on Hardwarezone.com [Maylyn the Review] ASUS RT-AC87U.
Can anyone ASUS @ SG ask if Ausus the Huawei USB Modem E3372S could be integrated into the firmware of the AC87.
With HiLink support
Thank´s
I tried this firmware, but after initial config, it got stuck every time I 'Applied settings' - the % never appeared - did 2 hard resets and no joy - back to 4950 now and it seems ok for now - anyone else have that ?
As I mentioned before, I was having that issue and resolved it by re-applying firmware into the router. Does it makes sense? No, but it worked for me. Give a try, you have nothing to lose.
Then hard reset and put all settings manually again as you do normally, don't use de cfg file (just in case I always clarify)
Replied through TapaTalk
Are you sure? This was reported fixed in 5556
Dear all,
I will be releasing another beta firmware for RT-AC87U. This firmware contains a lot of fix bugs and improvement.
RT-AC87U_3.0.0.4_378_5556-Unofficial Beta Firmware
Update dnsmasq to v2.73rc4-1
Update to brcm sdk 6.37.14.105
Update support Territory code
Update [IPTV] Add Meo profile for RT-AC87U
Update User interface
Fix GUI bug
Fix 5G WPS pincode 12345670 issue
Fix NAT loopback issue
Fix [dualwan] disable 3rd 5G guest network and wan2 used its mac address
Fix dead loop message only for vlanX case
Fix Traffic Monitor can not display correctly on Wired traffic
Fix [Adaptive QoS] WAN is DHCP Traffic Monitor can not display the WAN Download / Upload flow correctly
Fix [Adaptive QoS] [Traffic Monitor issue] Traffic Monitor "Wired" is not displayed correctly flow (WAN, wireless normal)
Fix [Traffic Monitor] Traffic Monitor without any display.
Fix [Administration] Save Profile check Transfer ASUS DDNS name leads to abnormal profiles
Fix [Wireless] happened some time after power 5GHz disappearance could not connect
Fix [Administration] in the presence of some settings can not successfully update the firmware
Important Notice:
Require hard reset.
Do not restore configure settings due to driver update.
Download: http://goo.gl/ZQByAz
Please feedback to me.
Best regard,
JK
http://forums.hardwarezone.com.sg/93839023-post3368.html
I did try that with no joy.. Will wait for the next one and try that...
I just want to add this unofficial firmware still has WPS bug of pin '12345670' as discussed in http://www.snbforums.com/posts/181485/
Did you do the required factory default reset, in case that weak PIN was written to nvram by a previous firmware?
A new beta build should be available soon apparently. Otherwise, I guess I could test it with build 378_5886 which was compiled only two days ago (that build was for testing a different issue, which was fixed in this build).
Does these recent updates have these issues fixed?
SSH if enabled open on WAN?
Network Key special characters ridicule ?
Haven't seen any update to QT firmware/driver since long time ( not talking about MIMU enable )
MU-MIMO still not enabled.
Did not try factory reset, will do. However pin '12345670' is not in nvram, it is buried inside the code (my guess), in nvram you have the real 'legit' pin.
Is it a pain in the a.. to factory reset whenever we need to upgrade firmware?
It's not always necessary. In this case it is, because it's specified in the original post from JK, in part due to the new Broadcom SDK used in this beta build.
What I usually do for these cases where I just want to test a new FW is I save a backup of my settings. Then I flash the new firmware, do a factory default reset, and reconfigure only the basics. I test what i need tested, and once done I reflash the original firmware, and then I restore my saved settings.
Did a factory reset with 3.0.0.4.378_5587, WPS still buggy with '12345670' . The only firmware that fixed the WPS issue was the one I posted in the WPS issue thread http://www.snbforums.com/posts/181485/
Thanks! Please report to your ASUS contacts if you have not done already so. It is a rather nasty bug...
Maybe someone forgot to merge it in master (or the fix got accidentally overwritten at some point - that's what happened with the smb issue a year or two ago).
I'll see what I get from this newer internal beta once I get the chance to test it.
Well, I can't test it. Both my Android tablet come back with "Another WPS session is in progress, try again in a few minutes", and my Windows 10 laptop was immediately reconnecting without asking any PIN once I press the "Start" button on the webui, even after I told it to forget my network...
With HiLink support
Thank´s
I'm looking for the same thing... I'm getting crazy to get mine to connect to the Huawei E5377 o_O
