# cat /etc/openvpn/client1/status
REMOTE,###.###.###.###:###,Static_Key
OpenVPN STATISTICS
Updated,2025-02-24 21:31:43
TUN/TAP read bytes,68
TUN/TAP write bytes,60
TCP/UDP read bytes,15897
TCP/UDP write bytes,6517
Auth read bytes,1164
END
# cat /var/lib/misc/dnsmasq.leases
A suggestion. Post a screen capture (redacting sensitive information) of what you are seeing so others have some context. Also post up your router model as well for more context.I'm in the process of migrating my VPN Clients to Asuswrt-Merlin 3004.388.8_4. I have found that even though the VPN Clients show connected, on the VPN Clients Page, the VPN Status Page is often Blank.
Is this a known issue?
Nope, it should work fine.Is this a known issue?
As with most web page rendering issues, check your browser developer console for errors from the page. Also try browsing directly to the ajax page that provides the status fields to look for any unusual output.Safari has a Blank VPN Status Page less often than Firefox, but both browsers have a Blank VPN Status Page more than they do not.
REMOTE,89.34.98.110:1194,Static_Key
OpenVPN STATISTICS
Updated,2025-02-26 12:12:54
TCP/UDP read bytes,6716
TCP/UDP write bytes,2207
Auth read bytes,108
pre-compress bytes,0
post-compress bytes,0
pre-decompress bytes,0
post-decompress bytes,0
END
Welcome To SNBForums
