Hi forum!
Bluesound (a Hi-Fi streaming solution similar to Sonos but with better quality etc.) claims that ASUS routers have issues with wireless clients (2.4GHz) which are commonly known. This seems to affect Bluesound components (and in my personal case only Bluesound). Problem is that the clients intermittently loose the connection with the router and doesn't re-connect. According to Bluesounds support, better results/stability can be achieved by changing some settings (below).
Router:
LAN -> IPTV: Enable multicast routing (IGMP Proxy) : Enabled
LAN -> IPTV: Enable efficient multicast forwarding (IGMP Snooping): Enabled
Wireless -> Professional -> Band 2.4GHz -> Enable IGMP Snooping: Enabled
Wireless -> Professional -> Band 2.4GHz -> Multicast Rate(Mbps): OFDM 12
Access Points:
Wireless -> Professional -> Band 2.4GHz -> Multicast Rate((Mbps): OFDM 12
My question is, is this something that is known with other 2.4GHz clients and is this something that is possible to rectify in the firmware and is this at all ASUS fault?
https://helpdesk.bluesound.com/discussions/viewtopic.php?f=9&t=2931
Have tried the latest Merlin (of course) firmware with RT-AC87U & RT-AC3200 with the same results.
Thanks!
Router:
Access Points:
Thanks!
