For 2.4GHz, the router makers should really consider allowing the routers to bond channels 1-11 in order to take full advantage of the 2.4GHz band. (40MHz is not wide enough)
Er, not.For 2.4GHz, the router makers should really consider allowing the routers to bond channels 1-11 in order to take full advantage of the 2.4GHz band. (40MHz is not wide enough)
Yeah, my tablet is the only device that I really WANT high wireless speeds. My laptop, well, yeah I use it, but 95% of the time I can get away with fairly pedestrian wireless speeds of maybe 10MB/sec and that would be plenty. Most places I am using it in my house I can easily wire it with gigabit speeds, but of course generally don't (but I don't have much in the way of wireless traffic most of the time and no outside wifi networks interfering with mine).
My tablet on the other hand, is a PITA to do wired (but it does have a USB3 port and I do have a USB3 GbE adapter) and I often transfer movies and such forth too it. So having something better than the 9.2MB/sec at most wireless capability that it has would be REALLY nice. I don't need AC1300 in it, but AC433, or even N300 would be very nice. One of the things I hope tablet makers FIX over the next generation or two of tablets. That and storage performance. Wifi interface and storage are two of the biggest weak spots of almost all midgrade and most high end tablets out there. The processors sure leave something to be desired compared to laptop or desktop processors, sure, but only so much you can do with physics.
However, it wouldn't cost much or take much extra power to bump from an N150 adapter to an AC433, or better yet, an AC867 wifi adapter as well as moving from frankly low performing eMMC solutions to at LEAST higher performing eMMC solutions, if not PCIe based NAND storage (the little that I can find, a low end eMMC 64GB package is only about $1.50-3 cheaper than a fairly high end 64GB eMMC package).
I kind of get why manufacturers cut corners, but it pisses me off that when you are spending $400-800 on a tablet, that they cheap out by $3-5 on what could significantly improve user experience (most performance usability issues aren't a slow CPU or GPU, they are slow storage/wireless performance loading webpages, games, applications, what have you).
I know people have their own opinions and certainly the pricing model turns a lot of people off, but I like Apple because I know exactly what I'm getting. In general, they don't cut those corners you're talking about, even if it means inflating the price a little bit.
Thread starter | Title | Forum | Replies | Date |
T | 4x4 2,4 Ghz increase coverage? | General Wi-Fi Discussion | 36 | |
S | WiFi 6 GHZ only works when Legion 5 is away from Netgear RAXE500 router | General Wi-Fi Discussion | 10 |
Welcome To SNBForums
