Bug: Wireless Log in AC87U in Media Bridge renders incomplete
oranheim
I have an AC87U running firmware 378.54_1 in Media Bridge mode.
When I go to System Log -> Wireless Log it causes the page to render incomplete. See screenshot.
Br, Ove
ac87u_wirelesslog-png.3968
Check your browser console for any reported Javascript error.
Javascript Error console in Safari:
[Warning] Invalid CSS property declaration at: * (form_style.css, line 67)
[Warning] Unexpected CSS token: : (form_style.css, line 144)
[Warning] Unexpected CSS token: : (form_style.css, line 225)
[Warning] Unexpected CSS token: : (form_style.css, line 262)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 339)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 344)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 813)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 849)
[Warning] Unexpected CSS token: : (form_style.css, line 1746)
[Warning] Unexpected CSS token: : (form_style.css, line 1762)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 1796)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 1827)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 1839)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 2262)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 2270)
[Warning] Invalid CSS property declaration at: * (form_style.css, line 2278)
[Warning] Unexpected CSS token: : (index_style.css, line 78)
[Warning] Unexpected CSS token: : (index_style.css, line 98)
[Warning] Unexpected CSS token: : (index_style.css, line 115)
[Warning] Unexpected CSS token: : (index_style.css, line 157)
[Warning] Invalid CSS property declaration at: * (index_style.css, line 407)
[Warning] Unexpected CSS token: z-index (index_style.css, line 416)
[Warning] Unexpected CSS token: : (index_style.css, line 816)
[Error] SyntaxError: Unexpected token ']'. Parse error.
    (anonymous function) (Main_WStatus_Content.asp, line 38)
[Error] ReferenceError: Can't find variable: initial
    onload (Main_WStatus_Content.asp, line 147)
Thanks. Post the content of the line referred here, so I can see the malformed Javascript code:
Line 38 is (my real mac is replaced XX):
wificlients5 = [-1];["XX:XX:XX:XX:XX:XX","","<unknown>","-32","1040","1170"," 69:32:39","AU",],"-1"];
HTML:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<html xmlns:v>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=Edge"/>
<meta http-equiv="Content-Type" content="text/html; charset=UTF-8">
<meta HTTP-EQUIV="Pragma" CONTENT="no-cache">
<meta HTTP-EQUIV="Expires" CONTENT="-1">
<link rel="shortcut icon" href="images/favicon.png">
<link rel="icon" href="images/favicon.png">
<title>ASUS Wireless Router RT-AC87U - Wireless Log</title>
<link rel="stylesheet" type="text/css" href="index_style.css">
<link rel="stylesheet" type="text/css" href="form_style.css">
<script language="JavaScript" type="text/javascript" src="/state.js"></script>
<script language="JavaScript" type="text/javascript" src="/general.js"></script>
<script language="JavaScript" type="text/javascript" src="/popup.js"></script>
<script language="JavaScript" type="text/javascript" src="/help.js"></script>
<script language="JavaScript" type="text/javascript" src="/jquery.js"></script>
<script language="JavaScript" type="text/javascript" src="/jquery.xdomainajax.js"></script>
<script language="JavaScript" type="text/javascript" src="/client_function.js"></script>
<style>
.wifiheader{
background-color:#475a5f;
color:#FFCC00;
p{
font-weight: bolder;
</style>
<script>
var $j = jQuery.noConflict();
overlib_str_tmp = "";
overlib.isOut = true;
var refreshRate = 3;
var timedEvent = 0;
dataarray24 = [];wificlients24 = [];
dataarray5 = ["NETTVERK","0","19","-38","161/80","YY:YY:YY:YY:YY:YY","Media Bridge"];
function initial(){
show_menu();
refreshRate = getRefresh();
get_wlclient_list();
function redraw(){
if (dataarray24.length == 0) {
document.getElementById('wifi24headerblock').innerHTML='<span class="wifiheader" style="font-size: 125%;">Wireless 2.4 GHz is disabled.</span>';
} else {
display_header(dataarray24, 'Wireless 2.4 GHz', document.getElementById('wifi24headerblock'));
display_clients(wificlients24, document.getElementById('wifi24block'));
if (band5g_support) {
if (wl_info.band5g_2_support) {
if (dataarray5.length == 0) {
document.getElementById('wifi5headerblock').innerHTML='<span class="wifiheader" style="font-size: 125%;">Wireless 5 GHz-1 is disabled.</span>';
} else {
display_header(dataarray5, 'Wireless 5 GHz-1', document.getElementById('wifi5headerblock'));
display_clients(wificlients5, document.getElementById('wifi5block'));
if (dataarray52.length == 0) {
document.getElementById('wifi52headerblock').innerHTML='<span class="wifiheader" style="font-size: 125%;">Wireless 5 GHz-2 is disabled.</span>';
} else {
display_header(dataarray52, 'Wireless 5 GHz-2', document.getElementById('wifi52headerblock'));
display_clients(wificlients52, document.getElementById('wifi52block'));
} else {
document.getElementById('wifi5headerblock').innerHTML='<span class="wifiheader" style="font-size: 125%;">Wireless 5 GHz is disabled.</span>';
} else {
display_header(dataarray5, 'Wireless 5 GHz', document.getElementById('wifi5headerblock'));
function display_clients(clientsarray, obj) {
var code, i, client, overlib_str;
code = '<table width="100%" id="24G" border="1" align="center" cellpadding="4" cellspacing="0" bordercolor="#6b8fa3" class="FormTable">';
code += '<thead><tr>';
code += '<td width=15%">MAC</td>';
code += '<td width="16%">IP</td>';
code += '<td width="16%">Name</td><td width="10%">RSSI</td><td width="18%">Rx / Tx Rate</td><td width="12%">Connected</td>';
code += '<td width="8%">Flags</td>';
code += '</tr></thead>';
if (clientsarray.length > 1) {
for (i = 0; i < clientsarray.length-1; ++i) {
client = clientsarray[i];
code += '<tr>';
overlib_str = "<p>MAC address:</p>" + client[0];
code += '<td><span style="margin-top:-15px; color: white;" class="link" onclick="oui_query(\'' + client[0] +'\');;overlib_str_tmp=\''+ overlib_str +'\';return overlib(\''+ overlib_str +'\');" onmouseout="nd();" style="cursor:pointer; text-decoration:underline;">'+ client[0] +'</span></td>';
code += '<td>' + client[1] + '</td>'; // IP
code += '<td>' + client[2] + '</td>'; // Name
code += '<td>' + client[3] + ' dBm</td>'; // RSSI
code += '<td>' + client[4] + ' / ' + client[5] +' Mbps</td>'; // Rate
code += '<td>' + client[6] + '</td>'; // Time
code += '<td>' + client[7] + '</td>'; // Flags
code += '</tr>';
} else {
code += '<tr><td colspan="7">No clients</td></tr>';
code += '</tr></table>';
obj.innerHTML = code;
function display_header(dataarray, title, obj) {
var code;
code = '<table width="100%" style="border: none;">';
code += '<thead><tr><span class="wifiheader" style="font-size: 125%;">' + title +'</span></tr></thead>';
code += '<tr><td colspan="3"><span class="wifiheader">SSID: </span>' + dataarray[0] + '</td><td colspan="2"><span class="wifiheader">Mode: </span>' + dataarray[6] + '</td></tr>';
code += '<tr><td><span class="wifiheader">RSSI: </span>' + dataarray[1] + ' dBm</td> <td><span class="wifiheader">SNR: </span>' + dataarray[2] +' dB</td> <td>';
code += '<span class="wifiheader">Noise: </span>' + dataarray[3] + ' dBm</td><td><span class="wifiheader">Channel: </span>'+ dataarray[4] + '</td>';
code += '<td><span class="wifiheader">BSSID: </span>' + dataarray[5] +'</td></tr></table>';
function get_wlclient_list() {
if (timedEvent) {
clearTimeout(timedEvent);
timedEvent = 0;
$j.ajax({
url: '/ajax_wificlients.asp',
dataType: 'script',
error: function(xhr){
success: function(response){
redraw();
if (refreshRate > 0)
timedEvent = setTimeout("get_wlclient_list();", refreshRate * 1000);
function getRefresh() {
val = parseInt(cookie.get('awrtm_wlrefresh'));
if ((val != 0) && (val != 1) && (val != 3) && (val != 5) && (val != 10))
val = 3;
document.getElementById('refreshrate').value = val;
return val;
function setRefresh(obj) {
refreshRate = obj.value;
cookie.set('awrtm_wlrefresh', refreshRate, 300);
</script>
</head>
<body onload="initial();">
<div id="TopBanner"></div>
<div id="Loading" class="popup_bg"></div>
<iframe name="hidden_frame" id="hidden_frame" src="" width="0" height="0" frameborder="0"></iframe>
<form method="post" name="form" action="apply.cgi" target="hidden_frame">
<input type="hidden" name="current_page" value="Main_WStatus_Content.asp">
<input type="hidden" name="next_page" value="Main_WStatus_Content.asp">
<input type="hidden" name="group_id" value="">
<input type="hidden" name="modified" value="0">
<input type="hidden" name="action_mode" value="">
<input type="hidden" name="action_script" value="">
<input type="hidden" name="action_wait" value="">
<input type="hidden" name="first_time" value="">
<input type="hidden" name="preferred_lang" id="preferred_lang" value="EN">
<input type="hidden" name="firmver" value="3.0.0.4">
<table class="content" align="center" cellpadding="0" cellspacing="0">
<tr>
<td width="17">&nbsp;</td>
<td valign="top" width="202">
<div id="mainMenu"></div>
<div id="subMenu"></div>
</td>
<td valign="top">
<div id="tabMenu" class="submenuBlock"></div>
<table width="98%" border="0" align="left" cellpadding="0" cellspacing="0">
<tr>
<td valign="top" >
<table width="760px" border="0" cellpadding="5" cellspacing="0" bordercolor="#6b8fa3" class="FormTitle" id="FormTitle">
<tr bgcolor="#4D595D">
<td valign="top">
<div>&nbsp;</div>
<div class="formfonttitle">System Log - Wireless Log</div>
<div style="margin-left:5px;margin-top:10px;margin-bottom:10px"><img src="/images/New_ui/export/line_export.png"></div>
<div class="formfontdesc">List of connected Wireless clients</div>
<table width="100%" border="1" align="center" cellpadding="4" cellspacing="0" bordercolor="#6b8fa3" class="FormTable">
<tr>
<th>Automatically refresh list every</th>
<td>
<select name="refreshrate" class="input_option" onchange="setRefresh(this);" id="refreshrate">
<option value="0">No refresh</option>
<option value="1">1 second</option>
<option value="3" selected>3 seconds</option>
<option value="5">5 seconds</option>
<option value="10">10 seconds</option>
</select>
</td>
</tr>
</table>
<br>
<div id="wifi24headerblock"></div>
<div id="wifi24block"></div>
<br><br>
<div id="wifi5headerblock"></div>
<div id="wifi5block"></div>
<br><br>
<div id="wifi52headerblock"></div>
<div id="wifi52block"></div>
<div>Flags: <span class="wifiheader">P</span>=Powersave Mode, <span class="wifiheader">S</span>=Short GI, <span class="wifiheader">T</span>=STBC, <span class="wifiheader">A</span>=Associated, <span class="wifiheader">U</span>=Authenticated, <span class="wifiheader">G</span>=Guest</div>
<br>
<div class="apply_gen">
<input type="button" onClick="location.href=location.href" value="Refresh" class="button_gen" >
</div>
</td>
</tr>
</table>
</td>
</tr>
</table>
</td>
</tr>
</table>
<div id="footer"></div>
</form>
</body>
</html>
Thanks, I see where there's a syntax error. I'll have to review that section of the code (it's different for the AC87U, and I couldn't test Media Bridge with that specific model as it was my fronting router).
If you like, please let me know if you want me to test any custom build to verify your fix.
Thanks for the confirmation.
