I looked at all my settings, and changed the below.
Yes it can, Media bridge acts as a wireless client that allows ethernet only devices to connect to the wireless network, you might be thinking repeater?If your RT-AC66_B1 router is in Media Bridge mode, it cannot be connected via Ethernet cable.
while lurking on this thread, it's occurred to me that something has been overlooked: the units of the speed measurement.I guess notI thought it would choose what was appropriate. Its an amazing difference now. It peaks at 64MB/s now with the same file.
Thanks so much for your help and pointing me in the right direction.
The Media Bridge is reporting it can connect (is connected?) at 1300Mbits per second
It makes no difference other that having the correct date and time appear in the system log.Media Bridge setup - don't forget to tell it what timezone it's in, and what clock reference to follow. It seems to have mattered on my setup.
OK, I don't know why but when I switch to WPA2 personal, the speed plummets again. Moving it back to WPA/WPA2 gets it back to the 64MB/s.Use WPA2-Personal only. WPA/WPA2-Personal is not very secure.
I understand the choice you are stating. I'm trying to troubleshoot which device is the problem. I don't have old devices on the 5ghz band. I do have some older printers etc on the 2.4 band.When you select WPA2-personal only the clients must authenticate with more secure WPA2 + AES. When you select WPA/WPA2-Personal you enable less secure WPA + TKIP authentication option. You have to decide what do you want - speed to one device vs security of your entire Wi-Fi network.
I will be careful what I wish forI don't know why the Media Bridge slows down with WPA2-Personal. The changes you make on the main router though affect your entire network. Your 2.4GHz radio settings are perhaps unrelated when the Media Bridge is connected to the 5GHz radio. Keep in mind regular high speed transfers over Wi-Fi to this Media Bridge will slow down your entire Wi-Fi network and perhaps your neighbors' Wi-Fi too. The available bandwidth per channel is shared between all devices using the same channels. Careful what you wish for.
The iperf through the media bridge is now below. Way higher than before.
Actually it shouldn't
Welcome To SNBForums
