I
infernoo
Guest
Have you tried OpenFiler?
Tim,
First of all, I have to thank you for your interesting articles. Most of them gave me good ideas to mount my own system or what to avoid when doing so.
I was working for some months trying to mount my DIY NAS waiting for propper components. Fortunately I was able to get a VIA C7 1GHz mini-itx system from a special offer (60€ with DVD reader, 40GB PATA Disk, 256MB and small case with external 50W power supply) and tried different OS to finally install OpenFiler on a 2GB CompactFlash with 2x1TB SATA Samsung drives and 1GB RAM. It works better than planned.
The main point here is Openfiler. I believe its very stable and could outperform Ubuntu on tests. It's free, but if you want you can purchase support. Its GUI is very easy to use and configuration options are wide enough. Many people has installed it on production SAN with succesfull results. You can check its forums.
It would be very helpfull if you give it a try and tell us (your readers) what do you think about it. Your opinion will be very appreciated.
Regards.
Tim,
Regards.
