The setting is on (Fig 7) of Build Your Own Atom-based NAS - Part 2 under "RAID problem notification options"
No, I didn't try failing the array. Maybe next time I have it fired up...
Oops! So it is!
Good luck with it. I also read the NewEgg reviews. Looks like a decent little system.I've thought some more about the MSI Wind PC barebones system (I'm the anonymous that posted before - finally got around to registering). I can't think of anything wrong with it, and the newegg reviews are extremely positive. So I've got it on order along with a Seagate 1.5TB sata disk, a samsung DVD burner, and a 2GB ram stick for it. I'll try to post back with my experiences.
Thanks for the report, Bill.I did not benchmark it, but it ran much faster than the DNS-323 and the Thecus N5200 (not pro) that I own. I copied around 1.4 TB of files, mostly large movie files) in less than 24 hours using Rsync (local gigabyte lan connection from an XP Pro computer).
Thanks for registering, Bill. Hope you come back often.I had installed 2 GB of ram in the Wind - probably overkill, but ram is so cheap now...
Hi Bill321 - I am curious about how you did the installation on the Wind PC. Did you have a CD drive, network install, or something else. Thanks.
As a newbie to linux, getting this working using webmin was a big help. But can anyone explain why using Ubuntu Server for this setup was necessary, rather than just standard Ubuntu Desktop? Is there something done here, that can't be done with standard Ubuntu?
wwarren
I used Ubuntu Server and Webmin based on a reader suggestion.As a newbie to linux, getting this working using webmin was a big help. But can anyone explain why using Ubuntu Server for this setup was necessary, rather than just standard Ubuntu Desktop? Is there something done here, that can't be done with standard Ubuntu?
Welcome To SNBForums
