CakeQOS CakeQoS-Merlin v2.0.0 alpha
In the Download stats section, is there suppose to be a 'Packets Sent' and 'Sent' ?
Ok. I thought it would be something like Packets Received.
It was discussed briefly in post 231:
I have noticed for a while now that every time I visit the CakeQOS-Merlin tab, the stats show very small numbers, like they were just reset. For example, I went there just now and it shows 11MB downloaded.
I don't know if it matters, but I have a custom /jffs/scripts/qos-start script, which adds some iptables rules that @dave14305 posted in the 386-2 beta pages a while back, to ensure Teams/Zoom take advantage of the Voice tin on upload.
Are you using spdMerlin? If so, my understanding is that it stops and restarts QOS every time it runs, so it would reset the Cake stats.
This has no impact on the issue you posted, but the Zoom rule in that post is incorrect. Zoom's ports are 8801:8810, not 8001:8010.
  • Like
Reactions: pdc
And also on that note, has there been any behind the scenes progress towards the application of a basic set of rules on the download side?
I am not running spdMerlin, though I am running connmon. I don't think it resets QOS though? It seems more like the logic to load the stats is also somehow resetting them.
I'm not too worried about it, just wanted to mention since this is alpha...
@dave14305 thanks for the note about Zoom, I will update my script.
Now that's it's possible to exclude pings from QoS in the latest version of connmon, I'm wondering whether Cake isn't stopped (and the stats reset). If you have this option enabled (exclude ping from QoS) it might do exactly the same as spdMerlin does: stop CakeQoS until it is done pinging and restart CakeQoS afterwards and then your stats have been set back to zero. Maybe ask on the connmon thread?
Edit: I think here's your answer: https://github.com/jackyaz/connmon/...1538297b458970b8646ab21542ed1ffb4ef3798d6R966. Seems like QoS is being stopped when you have Exclude ping from QoS enabled.
  • Like
Reactions: pdc
Okay, a question now that my stats are working :)
I just did a 6GB download and got a 10% drop rate. I got good download speeds, but I'm guessing the drops are cake throttling, and I should consider dropping my bandwidth a bit? It's currently at 97% (82.5/85) so probably on the high side... I'll drop it down to 94% (80/85) and see how that goes.
Here are the full stats:
Tin 0
Threshold Rate84,480 Kbit
Target1.5 ms
Interval30 ms
Peak Delay9.97 ms
Average Delay1.5 ms
Sparse Delay16 μs
Backlog0 B
Packets Sent4,558,266
Sent6.18 GB
Hash Indirect Hits36,476
Hash Misses24,875
Hash Collisions0
Drops455,757
ECN Marked Packets0
Dropped ACK Packets0
Sparse Flows1
Bulk Flows1
Unresponsive Flows0
Max Packet Length1,514
Flow Quantum1,514
I also have ack filtering on upload (connection is 85/6 or 14:1 so pretty asymmetrical) and it ended up dropping 10% of the acks. Very few packet drops on upload though so I think that's good.
Tin 0
Target1.5 ms
Interval30 ms
Peak Delay9.97 ms
Average Delay1.5 ms
Sparse Delay16 μs
Backlog0 B
Sent6.18 GB
Hash Misses24,875
Hash Collisions0
Drops455,757
ECN Marked Packets0
Sparse Flows1
Bulk Flows1
Unresponsive Flows0
Flow Quantum1,514
Your target and interval look low. Do you get the same values running tc -s qdisc at the command line? Or have you changed the rtt?
  • Like
Reactions: pdc
Sorry, when I changed the threshold to 80 Mb/s it reset the stats. However, yes I am running "regional" (rtt 30ms). I'm in the midwest US and it did seem like most sites were in that ping range.
Next time I do a large download I'll check tc output against stats. Currently with ~900 MB downstream they match. 730,771 packets sent and only 15,089 drops, though that's for general web browsing and not a high bandwidth download, if that matters.
You are probably seeing drops when packets take longer than 1.5ms (target) to leave the queue. I would reset this back to default (internet) and observe your drops.
Question about using Cake with Wireguard
First off, big thanks to the developers of this cake-qos code! I have been running this on my ac-86u for a week or so now and I really appreciate having the GUI for easy tweaks and additional insight into the stats.
I have noticed during bufferbloat tests (waveform.com) that my latency is significantly higher when running the test from a computer with an active Wireguard VPN connection.
Is this an expected outcome? Are there any cake settings that I can tweak to improve speed/latency when connected via a Wireguard connection? I should add that I have a standard DOCSIS (comcast) internet connection (120/6), and right now I have cake configured for DOCSIS.
I've pasted two bufferbloat test results below to show the significant latency difference between tests from the same device without Wireguard (top) and with Wireguard (bottom).
Wireguard not running
With Wireguard running
VPNs were invented for security and have considerable overhead. You should not expect good performance using a VPN
Morris
You should also be getting better than a B rating on your non-Wireguard test too.
How much of a margin do you have to add to your download bandwidth before that download latency drops below +10ms?
Morris
I have a full time VPN with FlexQoS and get A/B bufferbloat rating. Without Flex I get C/Ds. I wld like to see if I would get the same rating with CAKE.
Maybe this weekend I'll try that!
Good point. I hadn't really played around with this before...just set my bandwidth limits to 85% of the nominal connection speed (120/6). Interestingly, I found that I needed to lower my download bandwidth all the way down to 75Mb/s in order to start seeing download latency close to +10ms.
Does this sound right? Maybe there are other settings I need to consider adjusting in order to achieve low latency with a higher download bandwidth.
