hm still thinking if I am using the right overhead param. I am using now ether-vlan.
my connection is done via optical cable and @home I have converter and splitter to ethernet and IPTV.
what do you think, is it correct overhead for my connection?
Adding the 'uninstall' option will bring it one step closer to amtm integration sooner. But for a version '0.0.2', this is a solid first release.![]()
unfortunately i think the very limited model support might be an unsurmountable barrier, but who knows!Adding the 'uninstall' option will bring it one step closer to amtm integration sooner. But for a version '0.0.2', this is a solid first release.![]()
/jffs/scripts/cake-qos enable
Broadcom Packet Flow Cache HW acceleration <DISABLED>
CPU Speed (*) ==> Disable
Changing power settings. Forcing cpu to max frequency.
Set cpuspeed to on(pwr config --cpuspeed on) to make it adaptive again
Broadcom Packet Flow Cache learning via BLOG disabled.
Broadcom Packet Flow Cache flushing the flows
/jffs/scripts/cake-qos: line 162: /opt/sbin/tc: not found
RTNETLINK answers: File exists
Jun 20 14:37:56 RT-AX88U-9D28 myusername: Cake Queue Management Enabled - settings: 40Mbit | 10Mbit | 4
Jun 20 14:37:56 RT-AX88U-9D28 myusername: Cake Queue Management Starting - settings: 40Mbit | 10Mbit | 4
/jffs/scripts/cake-qos install ax88u
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 16420 100 16420 0 0 50214 0 --:--:-- --:--:-- --:--:-- 54370
100 180k 100 180k 0 0 428k 0 --:--:-- --:--:-- --:--:-- 454k
Package sched-cake-oot (2020-05-28-a5dccfd8-ax) installed in root is up to date.
Installing tc-adv (4.16.0-git-20191110) to root...
Installing libnl-tiny (2019-10-29-0219008c-1) to root...
Downloading http://bin.entware.net/aarch64-k3.10/libnl-tiny_2019-10-29-0219008c-1_aarch64-3.10.ipk
Collected errors:
* opkg_install_pkg: Package size mismatch: libnl-tiny is 18666 bytes, expecting 18679 bytes
* opkg_install_cmd: Cannot install package tc-adv.
Also this is the install note:
Code:/jffs/scripts/cake-qos install ax88u % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 16420 100 16420 0 0 50214 0 --:--:-- --:--:-- --:--:-- 54370 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 180k 100 180k 0 0 428k 0 --:--:-- --:--:-- --:--:-- 454k Package sched-cake-oot (2020-05-28-a5dccfd8-ax) installed in root is up to date. Installing tc-adv (4.16.0-git-20191110) to root... Installing libnl-tiny (2019-10-29-0219008c-1) to root... Downloading http://bin.entware.net/aarch64-k3.10/libnl-tiny_2019-10-29-0219008c-1_aarch64-3.10.ipk Collected errors: * opkg_install_pkg: Package size mismatch: libnl-tiny is 18666 bytes, expecting 18679 bytes * opkg_install_cmd: Cannot install package tc-adv.
How to add overhead on this line if it's value is 4
This doesn't work.Code:/jffs/scripts/cake-qos enable 37.5Mbit 9.5Mbit "4"
Question:
your github prereqs say "Not recommended for connection up/down of 250Mbps or higher".
Do you mean if EITHER the upload or download is 250+, you don't recommend this script? Or are you referring to symmetric connections (both upload and download are the same; i.e. 250mbps / 250mbps)
Also, you may want to specify which versions of the Asuswrt-Merlin firmwares have been tested with this script.
The command was /jffs/scripts/cake-qos 37.5Mbit 9.5Mbit ether-vlanNot sure which command is "4". Here is the link to the Overhead additional parameters you can use, I'll add it to the repo/1st page. This is to provide similar functionality to the ATM overheads in the Traditional/Adpative/FreshJR scripts.
https://man7.org/linux/man-pages/man8/tc-cake.8.html#OVERHEAD_COMPENSATION_PARAMETERS
Same here A+ across the board.I am curious on speedtests/bufferbloat tests if you enable/start at your Teksavvy linespeed. I haven't been using any % for a couple days now and running smooth A+s across the board.
Can anyone post screenshots of their connmon and Speedtest graphs showing before and after cake install/config?
At the end:
- No Trend - better privacy posture
- Works with Suricata
- Simply works - little to no config required
Privacy is increasingly important to me, and I’m keeping an eye on Suricata (last I checked, it wasn’t quite ready for mainstream use), and the ease of getting it going makes is a huge plus for people who generally don’t have the confidence or patience to config/troubleshoot.
It looks like your ping spikes have calmed down in a significant way; gamers on cable will appreciate cake.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
