24h with a stressful environment, with multiple connections. Stable network. Very good!
Code:CakeQOS-Merlin - ( 0Mbit | 0Mbit | besteffort | unlimited ack-filter dual-srchost )
I get woeful bufferbloat results on my VDSL connection using those settings. Numbers in the several tens of ms.
Simply setting "bridged-ptm" and then entering valid rate limits works best on my connection.
However, in my tinkering tonight I have noticed that there is a problem with the rate settings.
I can no longer set my upload speed as "8.9" Mbit. The script says that 8.9 is not a valid number, however it has had no problem accepting that number in the past.
It also doesn't interpret 8900kbit as a valid entry either.
Can we get this reverted so that it will accept decimal places again please!
connection appears to be symmetrical?
Good for use on egress traffic from a LAN to the internet, where it'll prevent any one LAN host from monopolising the uplink, regardless of the number of flows they use.
dual-srchost:
triple-isolate (default) is already applied by default in CakeQOS with options nonat
why do you prefer dual-srchost?
triple-isolate (default) is already applied by default in CakeQOS with options nonatprevent any one LAN host from monopolising the uplink, regardless of the number of flows they use.
No.From the screenshots, it seems to me that the DL and UL parameters are reversed??
I think the point being made here is that you can have dual-srchost OR triple-isolate, but not both. It doesn't make sense that you can apply both.triple-isolate (default) is already applied by default in CakeQOS with options nonat
that's correct. i'm trying to understand why/when one would be better over the other.I think the point being made here is that you can have dual-srchost OR triple-isolate, but not both. It doesn't make sense that you can apply both.
CakeQOS-Merlin: > Download Status:
qdisc cake 8024: dev ifb9eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat wash ingress ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce
CakeQOS-Merlin: > Upload Status:
qdisc cake 8023: dev eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat nowash ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce
Code:CakeQOS-Merlin: > Download Status: qdisc cake 8024: dev ifb9eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat wash ingress ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce CakeQOS-Merlin: > Upload Status: qdisc cake 8023: dev eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat nowash ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce
qdisc cake 801a: dev ifb9eth0 root refcnt 2 bandwidth unlimited besteffort triple-isolate nat wash ingress ack-filter split-gso rtt 100.0ms noatm overhead 18 mpu 64 no-sce
qdisc cake 8019: dev eth0 root refcnt 2 bandwidth unlimited besteffort triple-isolate nat nowash ack-filter split-gso rtt 100.0ms noatm overhead 18 mpu 64 no-sce
I can't see triple-isolate in that status you sent. All applied options will be listed in that status feedback message, even the ones that are not manually specified but are applied by default.Code:CakeQOS-Merlin: > Download Status: qdisc cake 8024: dev ifb9eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat wash ingress ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce CakeQOS-Merlin: > Upload Status: qdisc cake 8023: dev eth0 root refcnt 2 bandwidth unlimited besteffort dual-srchost nat nowash ack-filter split-gso rtt 100.0ms raw overhead 0 no-sce
by the way, wasn't there a 1.0.2 script version coming up?
mkdir -p /jffs/addons/cake-qos && /usr/sbin/curl -s "https://raw.githubusercon
tent.com/ttgapers/cakeqos-merlin/v1.0.2/cake-qos.sh" -o "/jffs/addons/cake-qos/cake-qos" && chmod 755 /jffs
/addons/cake-qos/cake-qos && sh /jffs/addons/cake-qos/cake-qos install
can't we ask @Odykrys or @robcore for instructions?![]()
i did a quick search and it sounds like they have been gone for a while?...
unless we figure out the build process for the binaries, we have a problem...
Welcome To SNBForums
