Adamm
Part of the Furniture
Probably a dumb question but I can't seem to find an answer after searching these posts or the install instructions, but do I need to enable QOS inside the router before I install CAKE?
No you don’t.
Guilty as charged:Hi,
I just changed my connection from a bad rsp with 50/20 to a good rsp 100/20
someone here suggested to use cake without d/l u/l numbers - how do i remove the d/l u/l numbers from the settings? do i set it to 0?
thanks,
Ben
yes i can access that but i assume i have to do the usb method for it to work which i haven't tried yet.this tells me you can access the command line. Have you tried issuing the command amtm?
enjoy... ;-D
thanks so much for the info!!!You don't need to install amtm if you're running RMerlin firmware 384.15_0 or later (it is built into the firmware).
The following guide may be helpful.
amtm - amtm step-by-step install guide - L&LD
This is a step-by-step guide that will show how to optimally set up a USB drive for Asus’ RMerlin powered routers that will at the very minimum allow for use of a swap file for your supported router. It will optionally install Entware properly too, all with the help of amtm by @thelonelycoder...www.snbforums.com
www.snbforums.com
Thanks for your replyGuilty as charged:
in the script, simply type in unlimited in your upload AND download configs along with whatever else
I may play some with mine, to see if the order in which they're listed is of any import or has any impact on performance
ssh into your routerThanks for your reply
i'm using cake-qos in merline which runs the .sh script for settings
the .sh script doesnt seem to support unlimited?
cake-qos settings dlspeed unlimited wouldnt work either
it expects a number and then adds Mbit after it
do i put it in optionsdl - ?
I have a similar setup, cable/docsis 100/10. After using @Linux_Chemist settings and doing some ping (rtt) measurements, I am getting all A's (and some A+!)
I also have installed spdMerlin. I have gotten 117Mbit down, 11Mbit up for months very consistent.
Measure a variety of ping times and there is a utility called betterspeedtst.sh that was in the /jffs/addons/util directory. I don't recall how it got there!!!!
If you don't have it installed on your router, here is the script:
#!/bin/sh# betterspeedtest.sh - Script to simulate http://speedtest.net# S - Pastebin.com
Pastebin.com is the number one paste tool since 2002. Pastebin is a website where you can store text online for a set period of time.pastebin.com
In any case, note that the default rtt is 100 mSec. I would bet your average is much lower.
My testing showed an average of 30 mSec. I believe that setting the more correct rtt made the biggest improvement in my case.
Here are my settings:
download speed: 110
upload speed: 11
Queue Priority: diffserv4
Download options: docsis nowash rtt 30000
Upload options: docsis ack-filter rtt 30000
Try those as a starting point.
Good luck
CakeQOS-Merlin: > Download Status:
qdisc cake 8007: dev ifb9eth0 root refcnt 2 bandwidth 125Mbit besteffort triple-isolate nat wash ingress no-ack-filter split-gso rtt 50.0ms raw overhead 0 no-sce
CakeQOS-Merlin: > Upload Status:
qdisc cake 8006: dev eth0 root refcnt 2 bandwidth 9Mbit besteffort triple-isolate nat nowash no-ack-filter split-gso rtt 50.0ms raw overhead 0 no-sce
After reading the recent observations on raw and unlimited download speeds I have revisited and adjusted my cake settings. My notional connection is 80/20, VDSL/PPPOE, I am in a metropolitan area and all my tests are subject to the usual variances to be expected from external noise, so YMMV.
My previous settings were
[1] --> Download Speed | [78 Mbit]
[2] --> Upload Speed | [19 Mbit]
[3] --> Queue Priority | [besteffort]
[4] --> Extra Download Options | [ack-filter pppoe-ptm diffserv4 rtt 80ms]
[5] --> Extra Upload Options | [ack-filter pppoe-ptm diffserv4 rtt 80ms]
They are now
[1] --> Download Speed | [77 Mbit]
[4] --> Extra Download Options | [raw diffserv4 rtt 80ms]
[5] --> Extra Upload Options | [raw diffserv4 rtt 80ms]
Observations
Adding raw removes the need to have either ack-filter or pppoe-ptm and provides slightly better throughput, latency and jitter. Adding either or both of them back (e.g. ack-filter raw pppoe-ptm diffserv4 rtt 80ms) gives a worse result.
Setting Speed to unlimited results in a very marginal increase in throughput at the expense of a substantial increase in both latency and jitter.
While reducing rtt marginally improves latency and jitter on for devices routed directly, after I go below 80ms, the throughput drops perceptibly on devices routed through a VPN on the router.
I tested using spdMerlin and betterspeedtest run on the router and DSL reports run on devices going direct and via VPN.
Allowing for variations between tests, I can see no difference; same latency, jitter and throughput both direct and via VPN.How does your connection respond if you remove diffserv4?
www.snbforums.com
I noticed the same thing a couple nights ago.Did the bufferbloat test through putty recently break?
www.snbforums.com
Hello ...
I'm here with a important question and NEED BIG advice from you guys ....
I'm in a bad scenario where my router ASUS RT-86U with 384.19 are rebooting at 1-4 days over and over again ...On this link I explain in more detail how stuff affected me ....
RT-AC86U Rebooting over and over
OK. It was just a thought. I don't have a Xbox. I thought it might be flip-flopping between the wired and wireless connections. I seen reports from people that say they've had issues with the Xbox's network once it's gone into standby. I don't know the details. Thank you for the suggestion...www.snbforums.com
I receive the advice to uninstall AIProtection ( because he is the bad guy ) and stay without but I lose Adaptive QOS with FreshQOS who work for me very well right now ....and to install CAKE instead. I read some posts here and what I understood is CAKE works very well with slow connections top recommended is 250.
Question ARE:
1. I lose serious speed with CAKE ?
Now I have 450-470 / 25 - 23 without QOS and 370 / 20 with FreshQOS active and other stuff on.
I need badly some QOS very well organized because I have a crowded network and almost all devices are online on most of the time.
2. Is this CAKE a solution ? work with Skynet and Diversion .... and so on ...devices etc ?
Look in attach about my network structure and on top of that put 6-10 wifi devices ....
Thank you in advance for your advice.
Also Big Thx to DAVID and other guys to guide me into FreshQOS
Cheers![]()
We use essential cookies to make this site work, and optional cookies to enhance your experience.
