Call me stupid but..where is the RunCmd.asp on a N66U
Mionix
I cant seem to find the Tools_RunCmd.asp section under the control panel on my RT-N66U running the latest build of Merlin.
Wanted to try my hand at overclocking but need to find the RunCmd section, when I copy and past the link directly I get a gray page with the following on it
Settings have been updated. Web page will now refresh.
Changes have been made to the IP address or port number. You will now be disconnected from RT-N66U.
To access the settings of RT-N66U, reconnect to the wireless network and use the updated IP address and port number.
So not sure what is going on and hoping that someone can lend a hand
thanks
The command page was removed back in April for security reasons. You need to use telnet or an ssh client to enter commands now.
problems with overclocking ASUS RT-N66U
Thanks all for your help
I did a Google search and using the info I found in this post
http://forums.smallnetbuilder.com/showthread.php?p=128340
I was able to get my N66U to match Shonk's OC in the above thread, but every time I change the clocks by even 1mhz higher the BogoMIPS drops back to its default. Am I doing something wrong? or are his clocks the highest you can get?
Temp is not an issue CPU temp is showing as 51C on the routers graph.
Some versions of the CFE don't allow overclocking. See here: http://forums.smallnetbuilder.com/showthread.php?t=17793
Much thanks so the next step would be to try and set clock speeds via the link/guide I found above?
Here is a screen shot of what my router System Information looks like thus far
We've added shellinabox to Entware repo!
  • Install it:
    opkg install shellinabox
  • Replace root user name by:
    sed -i 's/root/admin/g' /opt/etc/init.d/S88shellinaboxd
  • Start it:
  • Type following URL in the Web browser:
    router.asus.com:4200
  • Have fun:
  • Install it:
  • Start it:
  • Have fun:
Very cool. Thanks
