mattnin
My router is an RT-N66R. I'm using firmware 374.43. I don't know what I'm doing wrong and why I can't VPN using my cellular network. I can connect to my VPN when I'm on wifi and at home on the same network as the router that I want to connect to. Here are my logs from the router,
Mar 23 15:48:27 pptpd[1152]: CTRL: Client xx.xx.150.30 control connection started
Mar 23 15:48:27 pptpd[1152]: CTRL: Starting call (launching pppd, opening GRE)
Mar 23 15:48:27 pptp[1153]: Plugin pptp.so loaded.
Mar 23 15:48:27 pptp[1153]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.22.19
Mar 23 15:48:27 pptp[1153]: pppd 2.4.5 started by admin, uid 0
Mar 23 15:48:27 pptp[1153]: Using interface ppp10
Mar 23 15:48:27 pptp[1153]: Connect: ppp10 <--> pptp (xx.xx.150.30)
Mar 23 15:48:57 pptp[1153]: LCP: timeout sending Config-Requests
Mar 23 15:48:57 pptp[1153]: Connection terminated.
Mar 23 15:48:57 pptp[1153]: Modem hangup
Mar 23 15:48:57 pptp[1153]: Exit.
Mar 23 15:48:57 pptpd[1152]: CTRL: Client pppd TERM sending
Mar 23 15:48:57 pptpd[1152]: CTRL: Client pppd finish wait
Mar 23 15:48:58 pptpd[1152]: CTRL: EOF or bad error reading ctrl packet length.
Mar 23 15:48:58 pptpd[1152]: CTRL: couldn't read packet header (exit)
Mar 23 15:48:58 pptpd[1152]: CTRL: Fatal error reading control message in disconnect sequence
Mar 23 15:48:58 pptpd[1152]: CTRL: Client xx.xx.150.30 control connection finished
Please help. I've set up my VPN in the past, and for the most part it's pretty much straight forward. But I'm having a hard time figuring this one out. I called my ISP and they say they aren't blocking any ports. I didn't call my phone company to see if VPN is blocked. I've tried connecting using a DDNS address, using the actual IP address of my modem, I'm at a loss. Please help someone
*I edited out my ip address using xx.xx for privacy*
