Hi friends!
I have an issue when I use smart connect. For me Smart Connect chooses control channel 6, in the 2.4Ghz band, even if it is very crowded in there.
As you might know the wifi system settings gets in to auto mode when smart connect is enabled. I would like to choose another control channel on my AC3200.
Is it possible to "hard code" this somewhere in any config file or do I have to disable smart connect t fix it?
Best Regards
Michael
Best Regards
Michael
