Change of names of partitions to shut down or disconnect USB hub AC68P
grinna
have a USB hub with 2 x 1TB hdd am with the following problem, I installed the trasmission in HDD with name sde1 but to shut down or disconnect the router hd, it changes the Partition name to sdc1, sda1, sdf1 ... and end up losing access to trasmission, how can I solve for the the router always the same names as the units? is there any script
I'm also looking through the forums for an answer to this. I would love a way to use device UUID's but surprisingly I havent found an answer or guide.
(I keep finding my partitions going from "Storage" to "Storage(1)" for some unknown reason. Then takes a long process of trying to rename the partition on a windows PC, then reconnecting to the router.)
Just had another thread on this one.....make sure 'Reducing USB 3 Interference' is disabled on the the 2.4GHz Wireless > Professional page.
http://www.snbforums.com/threads/us...ed-to-the-disk-label.26101/page-2#post-206072
