channel 3: open failed: administratively prohibited:
voipair
So trying to get crashplan working on ac68u, asuswrt-merlin 378.55 debian chroot
Crashplan gui runs on one pc and talks to engine running in chroot on router
on desktop enter
ssh -L 4200:127.0.0.1:4243 admin@192.168.12.1
telnet localhost 4200
in the routers shell the following text appears (title of post) and i don't know what it means. This occurss every time i run the telnet command.
Searching it looks like an ssh restriction, but didn't find where to edit those files on the router. Does anyone have any idea where i could look next, logs etc
thanks
really i just need a way to allow the router to forward ports to crashplan,
telneting without the ssh to routers ip address results in refused, but when i telnet to port 4242 the crashplan incoming connection for backups i succusfully connect. So somehow crashplan PNP has opened up the ports on the router but I cant figure out how to do it, i thought i did as i have this is working for Bubble at http://192.168.12.1:58050/#main
my iptables --list is
admin@RT-AC68U:/tmp/home/root# iptables --list
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT tcp -- anywhere anywhere tcp dpt:4243
ACCEPT tcp -- anywhere anywhere tcp dpt:4200
ACCEPT tcp -- anywhere anywhere tcp dpt:58051
ACCEPT tcp -- anywhere anywhere tcp dpt:58050
logdrop icmp -- anywhere anywhere icmp echo-request
logdrop all -- anywhere anywhere state INVALID
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT all -- anywhere anywhere state NEW
ACCEPT udp -- anywhere anywhere udp spt:bootps dpt:bootpc
ACCEPT tcp -- anywhere anywhere tcp dpt:ftp
ACCEPT tcp -- anywhere anywhere tcp dpt:8082
ACCEPT tcp -- anywhere anywhere tcp dpt:https
ACCEPT icmp -- anywhere anywhere icmp !echo-request
ACCEPT tcp -- anywhere anywhere tcp dpt:1723
ACCEPT gre -- anywhere anywhere
Chain FORWARD (policy DROP)
ACCEPT all -- anywhere anywhere ctstate DNAT
Chain OUTPUT (policy ACCEPT)
Chain FUPNP (0 references)
Chain PControls (0 references)
Chain logaccept (0 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "ACCEPT "
Chain logdrop (5 references)
LOG all -- anywhere anywhere state NEW LOG level warning tcp-sequence tcp-options ip-options prefix "DROP "
DROP all -- anywhere anywhere
I dont think i need this solved any more the crashplan engine wasn't listening on all interfaces so i changed that and now hopefully don't need to ssh.
Just stumbled across where to enable this in the asuswrt-merlin interface
Administration - System - SSH Daemon - Allow SSH Port Forwarding
@voipair
Thank you for providing this update, after the fact.
It did the trick!
Thanks!
Gary
