Matthew Patrick
Hey. I was wondering if on 5ghz i use 80mhz channel bandwidth , then i try to connect from devices that can connect at max 40mhz bandwidth on 5ghz.. Will it connect? Or not? Thx cuz on 2.4ghz even if i set 40mhz. The mac can still use it with 20mhz (mac always use 20mhz on 2.4ghz)
Thx
Cheers
Thx
Cheers
