Chaotic UTC and local time in merlin
Yeah, I spotted the tmpstr issue but missed the typo for UTC. Like I said, I don't understand their thinking for this. Maybe they simply forgot to assign UTC-9 to tmpstr.
EDIT: It looks like technically UCT is a valid synonym UTC.
For the `date` command, the three-letter string of `TZ` is not that important. It is the signed number that controls the time zone.
# TZ="ABC-9" date
Sat Jun 11 11:04:47 ABC 2022
# TZ="XYZ-9" date
Sat Jun 11 11:05:08 XYZ 2022
For consistency and readability of the source code, it should be normalized to use, for example, only 'UTC' for Coordinated Universal Time.
I've created a PR #818 to fix this.
C:
   if (nvram_match("time_zone", "JST")) {
       nvram_set("time_zone_x", "UTC-9");
       tmpstr="JST-9";
You've got the right idea for the fix in your PR, but the incorrect syntax in this line: tmpstr="JST-9";
The correct syntax would be:
C:
sprintf (tmpstr, "%s", "JST-9");
// OR even better //
snprintf (tmpstr, sizeof(tmpstr), "%s", "JST-9");
FYI.
C:
       tmpstr="JST-9";
C:
FYI.
Fixed. Thank you so much for your correction. Portal
