Cron jobs are run by the system, independent of any interaction whatsoever through the WebUI Syslog page.I am having a problem with Chrome when browsing syslog from the UI.
I am using 380.68.0 on an RT-3100.
If I review the syslog from the UI. It appears the scripts in cron are not executing.
I then switched to IE 11 it shows the scripts are actually running.
I have been using that to see if the cron jobs are still there.I would check the output of the following first to see if the crons actually exist, then work from there;
Code:cru l
I'll have to think about that for a while(Just kidding.)!Cron jobs are run by the system, independent of any interaction whatsoever through the WebUI Syslog page.
Are you sure what you think you (don't) see is what you think is wrong?
Welcome To SNBForums
