Xfinity upgraded my service to their DOCSIS 3.1 product which offers 1Gbps download speeds. They bring you a Technicolor model TC4400 cable modem and a Netgear R8000 router. As far as I can tell there is nothing special about the R8000 or its configuration. It appears to be a standard, off the shelf model.
When they connect that modem to that router, you get speeds approaching 1Gbps downstream over a gigabit ethernet connection. However, when I connect that same modem directly to my Cisco RV320 router instead of the R8000, speeds drop to around 350Mbps.
I played around with several configurations, and at the moment I have the TC4400 connected to the wan port on the R8000 and one of the wan ports on the Rv320 connected to a lan port on the R8000. In that configuration, I get speeds around 600Mbps - 650Mbps.
The RV320 is supposed to get around 900Mbps of wan > lan throughput. I read the review on SNB of the RV32o and made the same bandwidth management adjustments noted in the article for getting maximum throughput, but the highest speed I have seen is about 650Mbps.
I am trying to figure out two things. The first is why would the RV320 be so much slower than the R8000 when connected directly to the TC4400 modem? Any ideas or suggestions of settings or other things to check would be greatly appreciated. This would be the ideal configuration for me and is how my network was configured previously.
The second thing I am trying to figure out is why the RV320 is only getting ~ 600Mbps of wan > lan throughput in the configuration I have now with the R8000 feeding the RV320 when it should be getting closer to 900Mbps.
