Compile Software on AX58U v2 possible ?
Coffee087
Hi :) I have an AX58U v2 with asuswrt merlin firmware, out of curiosity I connected to the router via SSH. That works too, now my question is, is it possible to compile programs on the router? My focus here is on TVheadend, which I would like to compile, is that possible or has someone already done that?
I've never heard of TVheadend but it looks like it's included in the Entware repository.
# opkg info tvheadend
Package: tvheadend
Version: 2023-06-05-2
Depends: libc, libssp, librt, libpthread, librt, libffi, libopenssl, libiconv-full, zlib, libdvbcsa
Status: unknown ok not-installed
Section: multimedia
Architecture: aarch64-3.10
Filename: tvheadend_2023-06-05-2_aarch64-3.10.ipk
Description: Tvheadend is a TV streaming server and recorder for Linux, FreeBSD and Android
 supporting DVB-S, DVB-S2, DVB-C, DVB-T, ATSC, IPTV, SAT>IP and HDHomeRun as input sources.
 Tvheadend offers the HTTP (VLC, MPlayer), HTSP (Kodi, Movian) and SAT>IP streaming.
@DJones yes, that is the firmware that I flashed.
@ColinTaylor How can I install the version of tvheadend? Sorry for the questions, this is new to me and I would like to test it. What kind of Linux distro is used on the router?
The router doesn't run a Linux distro. It runs an embedded OS with a Linux kernel designed for low spec devices. Its functionality can be expanded through the use of Entware packages but it lacks support for many things, e.g. a desktop GUI, most hardware peripherals, etc.
What are you trying to do with TV Headend? As an IPTV streamer, you might just about get it to run for a single client. But if you've a USB TV card plugged into the router, I think you may struggle to get the devices to work.
*I've used this on a Rpi4 with dedicated decoder board, and it was good at the time - but i'd tend to think that time has passed!
