Connection from router to web server
David G
I've noticed a connection from my RT-AC66U to a web server I host.
It appears to just be doing a 'GET /' on the web server.
The requests appear to be happening a little bit after the top of the hour.
This is a sample of the log entries I've seen ...
192.168.1.1 - - [10/Apr/2016:20:01:51 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:21:01:56 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:21:02:07 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:22:01:53 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:22:02:06 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:23:01:49 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [10/Apr/2016:23:01:56 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:00:01:42 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:00:01:49 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:01:02:06 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:01:02:12 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:02:01:48 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:02:01:55 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
192.168.1.1 - - [11/Apr/2016:03:01:50 -0500] "GET / HTTP/1.1" 200 1408 "-" "-"
Anyone know what might be causing it?
david
Also, FWIW, I have the router set to send syslog messages to the system running the web server.
That's the networkmap hourly rescans.
OK, obviously nothing harmful.
Might not be bad to add a user-agent so the access can be identified.
david
I'd have to see if it can easily be done (that networkmap code is from Asus).
Not a huge deal if it's difficult ... the behavior has been explained, I'm OK with that.
In the meantime, if those scans themselves are a nuisance, you can disable them under Tools -> Other Settings.
