connmon connmon - Internet connection monitoring
RMerlin tweeted just the other day that certain things are going to be GUI configurable in the nearish future, if I recall and understood correctly, with Diversion leading the way. I’m hoping Jack’s scripts will be as well.
Many of us are testing the Skynet Beta feature that this API enabled. :)
Somehow, that doesn’t have any issue in sticking to my brain. It’s the important gongs that fly away.
It may be the browser - I use Brave, and it blocks JavaScript unless I specifically deactivate that, which is likely the case because it worked as it should in chrome. I’ll try that tomorrow and let you know. Why I didn’t think of that before I posted, I can’t say.
So much of the internet uses javascript, blocking it seems like a pointless exercise imho
Turns out that Brave was indeed blocking something...preventing the browser from recognizing the device. I suspect I may need to re-import my ca.crt into Brave - there have been many upgrades - rather than simply into the OS. (probably wouldn't hurt there, either).
Anyway, @Jack Yaz just wanted to let you know it's on my end...your work is all good.
Just noticed I now have two instances of uptime monitoring to running on my AC86.
When I first noticed it only one had data to display. After forcing a second update they both have data. Third forced update didn't eliminate either of the instances.
@CaptainSTX a reboot fixes that. Not sure if anything can be done without doing so?
