Creating minidlna.postconf
jacob0910
I'm interested in becoming more familiar with postconf, so I thought I'd start out with minidlna.postconf and use it to add a video path.
I created minidlna.postconf with a text editor, Notepad to be precise, with the following:
#!/bin/sh
CONFIG=$1
source /usr/sbin/helper.sh
pc_append "media_dir=V,/mnt/MEDIAEXT3/video" $CONFIG
...copied the file to /jffs/scripts and made it executable:
chmod a+rx /jffs/scripts/minidlna.postconf
After rebooting the router (AC66U 376.48_3), I cannot see the video share. Am I missing a step?
Use Notepad++ for linux scripts, normal windows notepad will never work.
Try to execute your script manually and you'll see the error
sh /jffs/scripts/minidlna.postconf
Thank you for the suggestion. I've recreated minidlna.postconf with Notepadd++. What's the issue with notepad? Just curious.
Manually running the script gives me the following error:
'jffs/scripts/minidlna.postconf: source: line 3: can't open '/usr/sbin/helper.sh
Listing the directory contents of /usr/sbin shows helper.sh:
-rwxr-xr-x    1 admin    root           876 Nov 20 12:26 helper.sh
Should I re-apply the firmware?
Use "appending conf files"
ipkg install nano
if using optware
opkg install nano
if using entware
Now create minidlna.conf.add
nano /jffs/scripts/minidlna.conf.add
Paste this line
Save with Ctrl-O, Confirm with Enter and exit nano editor with Ctrl-X
Make script executable
chmod a+rx /jffs/scripts/minidlna.conf.add
Reboot router
reboot
Login again and check if your line is added to minidlna.conf
cat /tmp/etc/minidlna.conf
You can have a look here for minidlna where minidlna.conf can be edited without other startup scripts, depends witch version you choose: optware, entware, debian.
https://www.asuswrt.eu
