i5js@asus:/tmp/home/root# brctl show
bridge name bridge id STP enabled interfaces
br0 8000.c87f54bf2584 no bond0
eth10
eth3
eth4
eth5
eth6
eth7
eth8
eth9
br4 8000.c87f54bf2591 yes eth1.504
eth10.504
eth2.504
eth3.504
eth4.504
eth5.504
eth6.504
eth7.504
eth8.504
eth9.504
wl2.1
... I was looking for information about the router AXE16000, and I've found that it is a tri-band router with the following frequencies 2.4 GHz / 5 GHz / 6 GHz.
... it seams that you have the following frequencies/options 2.4 GHz, 5 GHz-1, 5 GHz-2, 6 GHz.
sbnMerlin was created with the frequencies/options 2.4 GHz and 5 GHz, so I must develop the order frequencies/options.
2.4GHz wl3
5GHz-1 wl0
5GHz-2 wl1
6GHz wl2
2.4GHz wl0
5GHz wl1
6GHz wl2
And there may be even more changes with the GT-BE98 Pro and other WiFi 7 routers...Thanks a lot for the feedback and support @Martinski.
I need to make some structural changes in the snbMerlin script to support those devices (GT-AXE11000 and GT-AXE16000) because there are more wireless interfaces and the bridges created by sbnMerlin are in conflict with other created by Asuswrt-Merlin.
Arriving from Amazon later today!
I don't have any of the WiFi 7 routers (or WiFi 7 clients for that matter), but based on information provided by @RMerlin and validated by a couple of users who generously supplied requested data via PMs, the following is the current info I have WRT wireless virtual interface mappings:Does anyone has this type of devices?
2.4GHz wl3
5GHz wl0
6GHz-1 wl1
6GHz-2 wl2
2.4GHz wl3
5GHz-1 wl0
5GHz-2 wl1
6GHz wl2
2.4GHz wl0
5GHz wl1
6GHz wl2
Thanks a lot for your help @Martinski, I just need some information.I don't have any of the WiFi 7 routers (or WiFi 7 clients for that matter), but based on information provided by @RMerlin and validated by a couple of users who generously supplied requested data via PMs, the following is the current info I have WRT wireless virtual interface mappings:
GT-BE98_PRO
Rich (BB code):2.4GHz wl3 5GHz wl0 6GHz-1 wl1 6GHz-2 wl2
GT-BE98 [Same mapping as the GT-AXE16000]
Rich (BB code):2.4GHz wl3 5GHz-1 wl0 5GHz-2 wl1 6GHz wl2
RT-BE96U [Same mapping as the GT-AXE11000]
Rich (BB code):2.4GHz wl0 5GHz wl1 6GHz wl2
I've already made the necessary changes to the scMerlin add-on (both webGUI & text-based SSH UI) and submitted a PR to @thelonelycoder's GitHub repository so if/when he merges the code changes, the next scMerlin release version should work with the above routers.
My 2 cents.
2.4GHz wl0 br1
5GHz wl1 br2
6GHz wl2 br3
2.4GHz wl3 br1
5GHz-1 wl0 br2
5GHz-2 wl1 br3
6GHz wl2 br4
2.4GHz wl3 br1
5GHz wl0 br2
6GHz-1 wl1 br3
6GHz-2 wl2 br4
Thanks @visortgw! Based on that I'll focus the developments on the other routers.Based upon initial experience with GT-BE98 Pro and Asus' Guest Network Pro implementation, I'm not sure that sbnMerlin would add anything. Each guest network can be configured with its own subnet, DHCP server, DNS, isolation, etc. Also, they've gone away from numbered guest networks. You simply add configurable guest networks (using one of many templates or completely custom), and then designate which AiMesh node(s) to mirror the guest network on (up to two (2) guest networks shared with each AiMesh node per band).
Nice… I guess it’s the GT-BE firmware right?
Yes, GT-BE98 Pro, but with Merlin 3006_102.1_beta1 firmware.Nice… I guess it’s the GT-BE firmware right?
Nop, Asus' Guest Network Pro Stock firmware….
sbnMerlin release v.1.2.6Thanks a lot for your help @Martinski, I just need some information.
I've made the following wireless and bridge mappings, with the Asuswrt-Merlin default bridges created when the Guest Network index 1 is enabled with the intranet access disabled.
Rich (BB code):2.4GHz wl0 br1 5GHz wl1 br2 6GHz wl2 br3
Rich (BB code):2.4GHz wl3 br1 5GHz-1 wl0 br2 5GHz-2 wl1 br3 6GHz wl2 br4
GT-BE98_PRO
Rich (BB code):2.4GHz wl3 br1 5GHz wl0 br2 6GHz-1 wl1 br3 6GHz-2 wl2 br4
Are these mappings correct?
Welcome To SNBForums
