sbnMerlin 1.2.6 - Network Isolation Tool based on Guest Networks, June 26 2024
Thanks Janico for your reply!
I'd like to manually assign IPs to clients and starting IP for DHCP server on br53. The guest network is propagated to AiMesh nodes. I used the standard settings listed on Github (i.e.):
br53_staticlist=<ab:cd:ef:01:23:45>192.168.108.10>8.8.8.8>HOMEPC<ab:cd:ef:01:23:46>192.168.108.11>>Xbox<ab:cd:ef:01:23:47>192.168.168.108.12>>
br53_dhcp_start="192.168.108.2"
But it seems the settings are not "processed" by the script and the DHCP still assign adresses to the clients, nor even starting from the dhcp_start address
@matthew_eli AiMesh bridges are classified by sbnMerlin as basic feature single-band bridge (bsb) and are the bridges: br1, br2, br3 or br4 depending of the device wireless capabilities. The following options are ones supported by sbnMerlin bsb:
## Template for (bsb) bridges ##
# br$_enabled=0
# br$_ifnames=""
# br$_dns1_x=""
# br$_dns2_x=""
# br$_staticlist=""
# br$_ap_isolate=1
# br$_allow_internet=1
# br$_allow_onewayaccess=0
# br$_allow_routeraccess=0
and the bridge(br53) is not supported by sbnMerlin. Please check if everything is ok by running the command:
Bash:
brctl show
# br$_enabled=0
# br$_ifnames=""
# br$_dns1_x=""
# br$_dns2_x=""
# br$_staticlist=""
# br$_ap_isolate=1
Bash:
brctl show
Brctl show:
bridge name     bridge id               STP enabled     interfaces
br0             8000.cc28aa3f3728       no              bond0
                                                        eth1
                                                        wl0.0
                                                        wl1.0
                                                        wl2.0
                                                        wl3.0
br53            8000.8a28aa3f3729       no              eth1.52
                                                        eth2.52
                                                        eth3.52
                                                        wl0.52
                                                        wl1.52
                                                        wl2.52
                                                        wl3.1
                                                        wl3.52
And I can confirm br53 is the one with Guest Network (in VLAN 52)
Brctl show:
                                                        eth1
                                                        wl0.0
                                                        wl1.0
                                                        wl2.0
                                                        wl3.0
                                                        eth2.52
                                                        eth3.52
                                                        wl0.52
                                                        wl1.52
                                                        wl2.52
                                                        wl3.1
                                                        wl3.52
Ok @matthew_eli definitely sbnMerlin script does not support that type of devices.
We could try to manage something, but i need your help to do that because I don't have that device.
Could you send me privately the following command:
ifconfig
I am having an issue getting this working, I got it working with br2 but I don't want to use aimesh wifi. I have the 2nd one enabled, 5Ghz-1 wl1., I have my config like this but it does not appear to be making the bridge.
br12_enabled=1 # Write your own settings for Bridge 12
br12_ifnames="eth3"
br12_ipaddr="192.168.110.1"
br12_netmask="255.255.255.0"
br12_dhcp_start="192.168.110.2"
br12_dhcp_end="192.168.110.254"
br12_dns1_x="9.9.9.9"
br12_dns2_x="149.112.112.112"
br12_staticlist=""
br12_ap_isolate=1
br12_allow_internet=1
br12_allow_onewayaccess=0
br12_allow_routeraccess=0
br12_ifnames="eth3"
br12_staticlist=""
br12_ap_isolate=1
Please send me the result of the following command:
brctl show
brctl show
br0 8000.e89c25040930 no eth1
eth2
eth3
eth4
eth6
eth7
eth8
wds0.0.1
wds0.0.2
wds0.0.3
wds2.0.1
wds2.0.2
wds2.0.3
wl1.2
eth2
eth3
eth4
eth6
eth7
eth8
wds0.0.1
wds0.0.2
wds0.0.3
wds2.0.1
wds2.0.2
wds2.0.3
wl1.2
ellenswamy@GT-AX11000_Pro-0930:/tmp/home/root#
Thank's @Ellenswamy for the feedback.
For that device the wireless guest interface wl1.2 is mapped with the bridge(br13).
Please try to change the options of your config file br12_* to br13_*
seems like the bridge is still not being created.
I changed everything to this: My router is a AX-GT11000 Pro if that helps
br13_enabled=1 # Write your own settings for Bridge 13
br13_ifnames="eth3"
br13_ipaddr="192.168.110.1"
br13_netmask="255.255.255.0"
br13_dhcp_start="192.168.110.2"
br13_dhcp_end="192.168.110.254"
br13_dns1_x="9.9.9.9"
br13_dns2_x="149.112.112.112"
br13_staticlist=""
br13_ap_isolate=1
br13_allow_internet=1
br13_allow_onewayaccess=1
br13_allow_routeraccess=0
@Underskore, with sbnMerlin you can adjust the bridge(br2) settings like ip address reservations, giving your IoT devices a static ip address and a different dns server. The denial of intranet access to bridge(br2) can be done on Asuswrt web interface. The sbnMerlin scripts helps to manage the Internet access to the bridge. I need more information about your adguardhome implementation, in order to advise you correctly. (You can send me a private message)
The Guest Wireless Networks (wl0.1 and wl1.1) are the only guest network used bu the AiMesh.
Hey sorry I haven't been on here recently. But with my setup I have a pi5 (or 4) running adguardhome. I was hoping to keep the default guest network setup asus has. So I can keep having the devices go between different aimesh nodes if needed, so I thought I'd be able to use this as a bridge so I could static IP them and forward them into the dns.
Hello Janico… sbnmerlin has been awesome for awhile now, so much that I have completely forgotten about it! But it has stopped passing internet to clients on br6. The only thing that I may have changed is two days ago I updated all the entware packages via AMTM. Are you aware of any issues that could be caused by that?
Hello @Mikey Dread, I’m not aware about any issues with the entware packages. But let’s find out. Could you send me privately the list of iptables?
@janico82
Finally had a chance to sit down and look at this script to see if I should replace my home brew bodge with your more thoughtful and insightful script. Very nicely done. Looking through your script, you are doing things a wee bit differently then myself - which is a good thing, you may be changing my mind on how to do this. Anyway, just wanted to say - very nicely done Sir.
@Viktor Jaep Unless I am blind, I don't see this script mentioned in your sticky list of addons.....
Cheers mate.
hi,
i think i finally have the script working (had yazfi etc installed) but noticed that applying the config only works if you have made changes to the config. There should be a way to force running the config again, because you know other things make changes, you make changes, you just need it to do it all again :)
cheers
Hi everybody 👋🏼
I was previously using Yazfi on a RT-AX88U and I wanted to switch to this fabulous sbnMerlin script.
A question came to my mind before deploying it.
I have an AdGuardHome instance hosted on the router, on 192.168.1.1. Does sbnMerlin allow to use it from a custom bridge with
`br$_dns1_x` and `br$_dns2_x`? Does it require `br$_allow_routeraccess=1`? Or even a custom rule?
Any insight would be greatly appreciated.
Cheers.
Hi everybody 👋🏼
Cheers.
I think I found an answer in the script, that should work on its own:
    # Allow bridge access to default router services: dns, dhcp and ntp.
    iptables -D INPUT -i "$bri_name" -p udp -m udp --dport 68 -j ACCEPT >/dev/null 2>&1
    iptables -D INPUT -i "$bri_name" -p udp -m udp --dport 67 -j ACCEPT >/dev/null 2>&1
    iptables -D INPUT -i "$bri_name" -p tcp -m tcp --dport 53 -j ACCEPT >/dev/null 2>&1
    iptables -D INPUT -i "$bri_name" -p udp -m udp --dport 53 -j ACCEPT >/dev/null 2>&1
    iptables -D INPUT -i "$bri_name" -p udp -m udp --dport 123 -j ACCEPT >/dev/null 2>&1
