I'm trying to set up a custom DDNS script on my ac68u running merlin 378.56
When I choose Custom and click apply, it just stays on the "applying settings..." screen indefinitely. I thought maybe this is because I have not created my ddns-start script yet
So I used SSH to get into the router and tried to create /jffs/scripts/ddns-start
I run into a few problems when I try this. First, I can used nano because command is not found. Second, when is check to see whats in the /jffs directory its empty. OK, so I try to mkdir scripts, but it says the directory cant be created because its a read-only file system.
What is the correct way to actually set up my router with a custom ddns script?
