custom dhcp for wireless guest networks
perkins1724
I am trying to setup custom dhcp using dnsmasq for my wireless guest networks (RT87U / Firmware:380.66).
i have a startup script that works for the 2.4GHz channels (virtual interfaces wl0.1, wl0.2 and wl0.3). However it does not work for the 5GHz channels (virtual interfaces vlan4000, vlan4001 and vlan4002).
Using ifconfig I can see that the 2.4GHz channels all have unique HWaddr values. However the 5GHz channels have an identical HWaddr value - which is the same as the eth0 / eth1 / vlan1 interfaces.
Using
nvram show | grep hwaddr | grep -E "wl0|wl1"
I can see that the hwaddr values for the wl0 nvram entries match the wl0 interfaces. However the hwaddr values for the wl1 nvram entries do not match the vlan400X interfaces.
Using tcpdump I also dont get any traffic on the vlan400X interfaces, it all seems to appear on the eth0/eth1/vlan1 interfaces instead - and this seems to be the issue with using dnsmasq.
Just to clarify - the guest networks all appear to work correctly from a mobile device perspective. However because the traffic is not coming through the vlan400X interfaces I can't get the dnsmasq assignments to correctly work.
Is there a possibility that the vlan400X interfaces are not being created correctly in this version of firmware? Are there instead supposed to be wl1/wl1.1/wl1.2/wl1.3 interfaces?
Any assistance / suggestions greatly appreciated.
Thanks Fitz Mutch. Yes, that is pretty much the script I am using. It also specifies that the 5Ghz guest interfaces should be coming up as wl1.1/wl1.2/wl1.3.
How can I go about debugging why the 5GHz interfaces are spawning as vlan4000/vlan4001/vlan4002 instead of wl1.1/wl1.2/wl1.3?
I am using an RT-AC87U with Firmware:380.66.
#ifconfig
br0       Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:192.168.1.1  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING ALLMULTI MULTICAST  MTU:1500  Metric:1
          RX packets:223277 errors:0 dropped:0 overruns:0 frame:0
          TX packets:14314 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:189728586 (180.9 MiB)  TX bytes:6627398 (6.3 MiB)
br0:0     Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:169.254.39.1  Bcast:169.254.39.255  Mask:255.255.255.0
eth0      Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:169.254.17.33  Bcast:169.254.255.255  Mask:255.255.0.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:225126 errors:0 dropped:0 overruns:0 frame:0
          TX packets:477835 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:195306414 (186.2 MiB)  TX bytes:310246969 (295.8 MiB)
          Interrupt:180 Base address:0x5000
eth1      Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          RX packets:156 errors:0 dropped:0 overruns:0 frame:398
          TX packets:12022 errors:191934 dropped:0 overruns:0 carrier:0
          RX bytes:32129 (31.3 KiB)  TX bytes:7505330 (7.1 MiB)
          Interrupt:163
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING MULTICAST  MTU:16436  Metric:1
          RX packets:961 errors:0 dropped:0 overruns:0 frame:0
          TX packets:961 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:176286 (172.1 KiB)  TX bytes:176286 (172.1 KiB)
ppp0      Link encap:Point-to-Point Protocol
          inet addr:XXX.XXX.XXX.XXX  P-t-P:XXX.XXX.XXX.XXX  Mask:255.255.255.255
          UP POINTOPOINT RUNNING MULTICAST  MTU:1492  Metric:1
          RX packets:1448 errors:0 dropped:0 overruns:0 frame:0
          TX packets:178244 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3
          RX bytes:493213 (481.6 KiB)  TX bytes:38020365 (36.2 MiB)
tap21     Link encap:Ethernet  HWaddr XX:XX:XX:XX:XX:XX
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:28 errors:0 dropped:0 overruns:0 frame:0
          TX packets:186844 errors:0 dropped:1076 overruns:0 carrier:0
          RX bytes:4047 (3.9 KiB)  TX bytes:170423320 (162.5 MiB)
vlan1     Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          RX packets:223663 errors:0 dropped:0 overruns:0 frame:0
          TX packets:15013 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:190766864 (181.9 MiB)  TX bytes:7037605 (6.7 MiB)
vlan4000  Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:192.168.104.1  Bcast:192.168.104.255  Mask:255.255.255.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:95630 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:87809333 (83.7 MiB)
vlan4001  Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:192.168.105.1  Bcast:192.168.105.255  Mask:255.255.255.0
          TX packets:94858 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:87104424 (83.0 MiB)
vlan4002  Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:50
          inet addr:192.168.106.1  Bcast:192.168.106.255  Mask:255.255.255.0
          TX packets:94071 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:86372335 (82.3 MiB)
wl0.1     Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:51
          inet addr:192.168.101.1  Bcast:192.168.101.255  Mask:255.255.255.0
          RX packets:0 errors:0 dropped:0 overruns:0 frame:398
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
wl0.2     Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:52
          inet addr:192.168.102.1  Bcast:192.168.102.255  Mask:255.255.255.0
          TX packets:1103 errors:96609 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:357120 (348.7 KiB)
wl0.3     Link encap:Ethernet  HWaddr XX:XX:XX:CA:61:53
          inet addr:192.168.103.1  Bcast:192.168.103.255  Mask:255.255.255.0
          TX packets:9019 errors:87981 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:4676863 (4.4 MiB)
The RT-AC87U does not have a wl1 interface because the 5 GHz interface isn't created within the firmware's environment but within a separate firmware running on a separate CPU. So, that hardware interface does not exist on the primary firmware environment.
Thankyou for that RMerlin.
I have tried a lot more, but I cant get it to work on the 5GHz side it looks like on the RT-AC87U it is not going to be possible to split the dhcp via dnsmasq for the 5GHz guest networks (the 2.4GHz guest networks work fine). It also appears (in my testing) that the setting to disable intranet access from the 5GHz guest networks does not work (well, on the RT-AC87U) which seems like a bit of a security hole particularly if anyone has created an open 5GHz guest network so I have disabled my 5GHz guest networks now anyway.
